Hello Rob and welcome to the forum. Unfortunately I have no knowledge of the saw or where to find a manual. However there are a lot of very knowledgeable scrollers on the forum and I'm sure someone will be able to point you in the right direction. When you start cutting, be sure to post pictures of your work. We are always eager to see everyone's projects.
Welcome to the village,
I also did a bunch of searching the for the person in the other topic that Dan posted and I came up empty handed too so my only suggestion is to keep an eye on ebay and other sites and maybe get lucky to find something sooner or later..  Usually I have a way of finding things that others cannot.. but on this particular saw.. I came up empty..
Hey there mate,
I am the one with the same saw as you, passed down through the family, and along the way the manual was lost, I still haven't had luck, but a guy on my post said it was similar to the Dremel 1671, and they do look close to it, so this is the manual I ended up going with, https://www.manualslib.com/manual/632662/Dremel-1671.html ,  and it seems to cover everything I needed it too, might help you too.
