Thanks for your Reply.  I have Been Thinking about another
way to hold stacks together before Cutting.  Sounds Good.
The Nailers I have been looking at will shoot 3/8" and that
to me sounds perfect.  Headless lil pins.  Gluing after all these
years has just seemed to be just another way to make a Finished
craft look bad.  Even tho I use a Clear Glue.  It still shows.  Anyway thanks again.  And How do I get the Format here to type in a Single Space?                           Danny  :+}
Danny, when I shoot the pins I lay my stack on the anvil of my bench vise so that if the pins do protrude, the anvil will flatten them. Always check so you don't scratch up your saw's table. I'm not sure about 3/8" pins though. I use 1/2".
I use a pin nailer all the time to hold stacks together, and to hold parts together for gluing.  I use 3/8" pins for stacking 1/8" wood, and when the pins protrude, just hit them with a hammer till they go back down.  I lightly rub over the ends to ensure they won't scratch the table and give them another whack if needed.
Tom
Hold the SHIFT key down when you change line, it will Single space your post
Warm Greetings my Old Good Friend....  OK I will give your test.
This is Exceptable for sure.  Kind of thought would be the Normal
Single line.  Is another thing to do.  Is there not a setting to automatically have it single line space?  Danny  :+}
