So I'm trying to build some new drawers for my bathroom cabinets. I thought it would be nice to use dovetails in the construction. So I bought a Porter Cable dovetail jig (http://www.amazon.com/gp/product/B000HG ... ayzcach-20) to cut the dovetails. I wanted to use plywood for the stability (and the cost...these aren't the greatest cabinets to begin with). I bought a sheet of 1/2" maple ply for the drawers. I spent all day trying to cut these dern things. Almost every time, the router will tear-out the plywood. It was terrible. I did everything I can think of to get a clean cut: blue tape, backer board, scrap wood on the front, slow speed, fast speed, ultra-slow feed rate, left to right, right to left. I even had a brand new router bit. Nothing really worked. Just out of curiosity, I tried using it on solid wood (pine, of all things). It worked like a charm. I've pretty much come to the conclusion that using dovetails on plywood is next to impossible. Is this a safe assumption? Or am I missing something?
The only thing I can think of, besides hand cutting (which would be the best for the plywood) maybe run a stright bit through first and then try the dove tail bit. I suspect that you may still end up with blow out, but it cant hurt to try.
  • 4 weeks later...
  • 2 weeks later...
I make signs out of Oak Ply. It cuts (surprisingly) well. I know you said you put a sacrificial piece of wood in front, but I would do it on both side, and maybe try
it on a different side of the ply....and then to second Messman, maybe use a straight bit to get most of it the cut done, then use the dovetail bit.
  • 3 weeks later...
