Bendita Posted January 13, 2015 Report Posted January 13, 2015 Just got to cut the hole and a little sanding then a finish on it then a piece of glass on top and its done oldhudson, LarB, Doug and 3 others 6 Quote
Rob Roy Posted January 13, 2015 Report Posted January 13, 2015 That's going to look Just amazing when it's finished off Hans. A remarkable job perfectly executed. You must have scroll sawing GENES, (not the DENIM ones). . Rob Roy. Bendita 1 Quote
Wilson's Woodworking Posted January 13, 2015 Report Posted January 13, 2015 I can't see it very good in the pictures. Just bring it over to my house and we can see what it will look like in front of my picture window. Fantastic table to go with a extraordinary piece of art! :thumbs: :thumbs: Bendita 1 Quote
Phantom Scroller Posted January 13, 2015 Report Posted January 13, 2015 Yes Hans that's going to look fantastic in some rich mans home, oh it already is. Roly Bendita 1 Quote
amazingkevin Posted January 13, 2015 Report Posted January 13, 2015 Not for everyone! It belongs in Guinness book of world records to start,and up from there!!!! Bendita 1 Quote
Bendita Posted January 13, 2015 Author Report Posted January 13, 2015 I have to confess I bought the legs as I don't have a lathe anymore other than that its just 3/4" pine. It came out just as I had envisioned it. Quote
Scrolling Steve Posted January 13, 2015 Report Posted January 13, 2015 Wow!...Hans that is a piece of work! Bendita 1 Quote
New Guy Posted January 14, 2015 Report Posted January 14, 2015 I want to see when you have a finish on it. Please post after the finsh is done. Quote
LarryEA Posted January 14, 2015 Report Posted January 14, 2015 Another piece of art by 'Bendita'. Bendita 1 Quote
heppnerguy Posted January 28, 2015 Report Posted January 28, 2015 Hans, Seeing it on the table brings up a really big question..HOW WERE YOU ABLE TO CUT SOMETHING THIS LARGE ON A SCROLL SAW ? Dick heppnerguy Quote
Bendita Posted January 28, 2015 Author Report Posted January 28, 2015 Hans, Seeing it on the table brings up a really big question..HOW WERE YOU ABLE TO CUT SOMETHING THIS LARGE ON A SCROLL SAW ? Dick heppnerguy I didn't cut the table on the scroll saw Dick just the insert the table I build it first then cut a hole in the middle with a jig saw then used a router for the rabbit to lay the scrolled insert in the scroll piece is only 16 x 22 and was all cut with #3 & #1 spirals Quote
amazingkevin Posted January 28, 2015 Report Posted January 28, 2015 I've done big projects before ,not as many holes though.Did you cut half of it right side up and the other half up side down .Mine were 20" x40"(2 of them). Also did you modifie your dewalt table bigger to keep the very fragile project as flat as possible while cutting.I know my projects got pretty flimsey with so many holes it was scary just to lift it up to thread the saw blade in the next hole. Quote
Bendita Posted January 28, 2015 Author Report Posted January 28, 2015 I've done big projects before ,not as many holes though.Did you cut half of it right side up and the other half up side down .Mine were 20" x40"(2 of them). Also did you modifie your dewalt table bigger to keep the very fragile project as flat as possible while cutting.I know my projects got pretty flimsey with so many holes it was scary just to lift it up to thread the saw blade in the next hole. Yes and Yes Kevin you pretty well have to support it as it gets to heavy to hold steady and cut at the same time as for cutting up side down yes of course as the saw only accommodates 20" but I used strictly spirals and there really is no picture on this pattern so it really didn't make a difference. amazingkevin 1 Quote
Doug Posted January 28, 2015 Report Posted January 28, 2015 Just got to cut the hole and a little sanding then a finish on it then a piece of glass on top and its done I want to see pictures of what the other grandchildren are getting. Bendita 1 Quote
