We have had a bit of a thaw, up to 30 deg. F so I was able to play with my new lathe yesterday. I think Ill need more practice with the skew before I try a pen. LOL This is different with no tool holder like a metal lathe. Turned a few really crappy spindles and have been watching a ton of You Tube videos. I don't have the best tools but today I'll put a sharpening on the gouge and skew and practice some more. I'm looking at a steeper learning curve than I expected.
I got a brand new Roller skate ,But no key !! Some day my Key will come !  sounds like some of my collections !
Carl, I remember that song by Melanie " You got a brand new pair of roller skates, your wife has a brand new key"
I think the song title is "You got a brand new key"
Your wife has had your 'key' for 53(?) years....:razz:
Your wife has had your 'key' for 53(?) years.... :razz:
As I read that ,my age snuck up on me ,I would bet there are many that did not know anything about the first roller skates were clamp to you hard soles shoes and the key allowed you to tighted them on to your shoes and were adjustable ,Had many accidents when one would come off ,or partially ! long before OSHA  took all the adventure out of being a kid , Yeah your right a bout her having the key which she still uses occasionally !LOL
I have done a lot of woodturning and a good tip I found was to polish your cutting edge to a mirror finish. This reduces drag and friction with the wood and cuts much easier. When using a skew place it flat on your tool rest, lift the left side of the skew about 5 degrees up and move the back of the handle about 5 degrees to the right. Then engage the wood and move to the right slowly. When you reach the end to the same thing in reverse to reach the other end and so on. By moving that 5 degrees it takes a much softer bite. The tool rest needs to be set just below center so the tool contact is at center. Good luck.
Edited by grosa
Craig all tools are a learning curve, don't give up. Treat it like a women, gently. ;)  Roly
If I treated my tools like a woman my tools would have left me a long time ago. I use my tools hard and to there maximum braking point and if they break I fix them or replace them. :lol:
