I am not using my saws, planer, drill, router untin my shop warms up above 40 degrees F.
The temp outside is minus 5 and inside my shop is plus 8. I just decided I did not want  to
use any 'motors' until the weather outside perked (is that OK Perk) up a bit.
Your thoughts.
Thermoshock is a real issue .I have old style flor. lites ,that come on like candles and have to warm to become usable and bright ,car engines ,go from -30 to 200 degrees ,oil is molasses at start up ,not good for wear ,all parts experience these wide expansion and contraction cycles ,it's a wonder some things can even survive ,multiples ,batteries is an another issue of great concern ,especially the new cars and electronics .out in the drastic themo-changes . So ,your right to allow as much room as possible to help reduce all these drastic changes even saw blades and cutters experience dramatic swings and stages of brittle ,and shrinkage !
Luckily ,my saw is in the constant temp.in the house and suffers none of the above .winter or summer ,but the vac. out side bears the brunt ,but nowhere near what you guys up north face! The vac. does enjoy some of the house heat as soon as it is activated ,and dust free at the motor and bearings !
Edited by Multifasited
They will work no doubt about that ,it's the wear and tear issue ,brushes makes sparks so the have a big temp swing to what  effect,?
Just not close to ideal ,there is little Ideal in weather you guys face everyday ,stuff still works , rails,cars ,trucks etc. Local Golf is the exception ! Ski slide and enjoy !
Just the trip alone out to the garage when it's 10 above is enough to make a person turn around and go back inside the house.  Perhaps I should have listened to my wife when she said I should finish off that part of the garage
It is about 5* here and I have problems getting my motor started to shovel snow. let alone starting the scroll saw. It's not really a good idea to use the scroll saw
now You wond't hert yourself bad just a couple of stitches the max.
I do it for a living so I have to run tools hot or cold. Most tools run fine but, the table saw always makes a whining sound in the cold weather. It seems like the bearings have a difficult time with the cold not the motor. In 16 years I replaced the bearings one time. last year I replaced the bearing and I am replacing them again because the shaft had a slight bend in it do to a kick back and thats why I need to do it again. Bearings cost $18 each the shaft cost $68 for my Jet saw. Today here in Tampa it is a cold 30 high today will be 55 I run the saws until the whining stops, then I start cutting. So it seems like the table saw is the only one that needs a sweater.
Edited by grosa
