vette07 Posted May 15, 2015 Report Posted May 15, 2015 Does anyone design patterns No Charge. I need one for a 1997 Corvette coupe and one for a 2007 Corvette coupe. amazingkevin 1 Quote
Kris Martinson Posted May 18, 2015 Report Posted May 18, 2015 I can give it a shot for you, if you provide good, high-contrast photos. Quote
heppnerguy Posted May 19, 2015 Report Posted May 19, 2015 Does anyone design patterns No Charge. I need one for a 1997 Corvette coupe and one for a 2007 Corvette coupe. when you are looking for a pattern to be made for you, vette07, make your post in the 'pattern request' farther down the forum page. you will get the pattern you need a little quicker there. Hope this helps you Dick heppnerguy Quote
grampa Posted May 19, 2015 Report Posted May 19, 2015 Hello Mae, A quick job so may need tidying up...........Paul bobscroll, ChelCass, joleet and 1 other 4 Quote
frankorona Posted May 19, 2015 Report Posted May 19, 2015 Wonderful patterns Grampa, thanks for your help. Quote
penquin Posted May 19, 2015 Report Posted May 19, 2015 Grampa, both are super really like then a lot. Thanks for sharing. jim penquin Quote
lawson56 Posted May 20, 2015 Report Posted May 20, 2015 Thanks Paul.Both look Fantastic! :thumbs: Quote
vette07 Posted May 20, 2015 Author Report Posted May 20, 2015 Thank you Grandpa for the patterns. They are great. Quote
vette07 Posted May 20, 2015 Author Report Posted May 20, 2015 This is the 1994 I need. Thank you Quote
grampa Posted May 22, 2015 Report Posted May 22, 2015 here you go, Hope its ok.......Paul ChelCass, wombatie and bobscroll 3 Quote
vette07 Posted May 23, 2015 Author Report Posted May 23, 2015 I can't get it to print right. When I print, it's blurry. What can I do to get a 8 x 10 clear print. Thank you Quote
redgam Posted May 23, 2015 Report Posted May 23, 2015 Thanks for sharing Grampa! They will for sure come to use in my next project. Quote
Birchbark Posted May 24, 2015 Report Posted May 24, 2015 Pauls pattern should print at 8x10 no problem. But it will be hard to cut any smaller than the 16.667 x 13.333 that it is now. The bridges will be to small in my opinion. If you wanted it that small he should have known that from the start. If i were you i would cut it as large as possible. Another nice pattern Paul. Russell Quote
