I've stack cut Crusifixs from â…›" BB. Before tapeing I spray glued gold tin foil onto each and then attached a Crusifix pattern downsized accordingly to fit onto cross. The Crusifix scrolled was attached to the cross with tiny brass nails. I've also have purchased plastic gold Crusifixs I believe from bearwood.com at a reasonable price like $5.00 ea or less. Now I could be wrong but it was a supplier that sold a selection of craft items such as mini clock inserts and etc. My memory is good but getting damn short as each year creeps up. Hopefully this info helps.
Edited by Ron Johnson
I Googled "Buy Crucifix" and found a good selection.  All had the Jesus attached to the Cross, but you could separate them.  Some were reasonably priced.
Also check with any Denomination of Churches for help.
jerry
Good idea Jerry seen them for about a fiver could do that just have to get the right size,
Thanks Ron. Looks like there hard to find, I've never thought of plastic. Roly
