Brianr24 Posted November 28, 2017 Report Posted November 28, 2017 (edited) I'm still working through the Kathy wise beginner projects. I'm happy with this except the color break on the tail but I'm not going to let it bother me.this was my 1rst attempt at color breaks. Next time I will glue together to sand . Okay it's bothering me. I'm going to have to try to fix it. S#$%$!&#ch! Edited November 28, 2017 by Brianr24 GPscroller, don watson, jollyred and 2 others 5 Quote
meflick Posted November 28, 2017 Report Posted November 28, 2017 (edited) Brian. Looks very nice. One thing that Judy Gale Roberts (JGR) teaches in her classes is to use a "sanding shim" for pieces that you want to sand together. Cut it to the size needed for the pieces you want to sand together. Then, use light duty double sided carpet tape to tape the pieces down to the sanding shim to hold them securely while you sand them together. Edited to add: Forgot Judy has an article about using sanding shims on her website. It can be found here: https://intarsia.com/blogs/news/using-sanding-shims Edited November 28, 2017 by meflick GPscroller and GrampaJim 2 Quote
amazingkevin Posted November 29, 2017 Report Posted November 29, 2017 19 hours ago, Brianr24 said: I'm still working through the Kathy wise beginner projects. I'm happy with this except the color break on the tail but I'm not going to let it bother me.this was my 1rst attempt at color breaks. Next time I will glue together to sand . Okay it's bothering me. I'm going to have to try to fix it. S#$%$!&#ch! Excellent work! Quote
Pictures in wood Posted December 2, 2017 Report Posted December 2, 2017 Nice looking piece, fine work ! Don't beat yourself up , Keep making sawdust! you will be amazed at your work in a year! Quote
Rob Posted December 3, 2017 Report Posted December 3, 2017 Yes the tail needs a bit of work but otherwise that is one very pretty kitty! Well done, Rob P.S. and I like dogs! Quote
