44 minutes ago, amazingkevin said:
How nice! Any pattern for us?
No pattern posted on the blog (linked in original post), but a decent enough explanation of the steps that I was able to trip my way through it.  LOL  She said she had plans she would pass along if you emailed her, but I haven't yet.
Nice work! Wery nice.
You can always buy things ... but self made is 100 times better!
The twisted corner - 45 degrees angle or just strait cut?
And i probably  will not cut so sharp endpoints. The little emty spot there ... i think it will by nicer if the endpoint is the thikness of the material. But ... just maybe i thinking so ...
Edited by innar20
Yep, I really need to sit down and figure out SketchUp, having a drawing with dimensions would definitely help out here.  Lessons-Learned and all that, would be to trim off the tips of the point.
17 hours ago, innar20 said:
Because of my opoinon  no need to make changes. Sorry.
I still love this table.
Waiting to electrician finish his work in my "shop" to try make one to myself.
I made the top and bottom by measuring the width of the boards, and cutting the length the same.  I think that was one of my problems, though, as the vertical-ish portions are hitting each other enough to throw off the "rotation".  My next one (there will be another!), I'm thinking of adding a 1/2 inch to the top/bottom pieces, that should separate the two out enough.  I also plan on lopping enough of the pointy-parts off so that everything is flush.  I'm thinking that some of this might be easier to accomplish with a miter saw, which  I do not own.....yet.....
  • 1 month later...
