don watson Posted August 30, 2018 Report Posted August 30, 2018 I have a jpg of a scene and would like to see the lines in red to make it easier to cut. Can I change the colour using Inkscape ??Do I need to use a different format eg png or bmp ?? Any help appreciated to get me looking in the right direction Don W OCtoolguy 1 Quote
loftyhermes Posted August 30, 2018 Report Posted August 30, 2018 Don, In Inkscape I trace the pattern then with the trace selected right click on the colour red at the bottom of the screen and then click on set stroke. OCtoolguy and don watson 1 1 Quote
Scrappile Posted August 30, 2018 Report Posted August 30, 2018 I use to know how to do it in Gimp,,, but it have been quite a while since I have done it. Some Gimp user will explain.... don watson and OCtoolguy 2 Quote
don watson Posted August 30, 2018 Author Report Posted August 30, 2018 @loftyhermes, I tried that but only got some dots of red at different places on the pattern. @Scrappile, thanks for that . Hope someone turns up soon. OCtoolguy 1 Quote
Scrappile Posted August 30, 2018 Report Posted August 30, 2018 It may be explained in the lessons in the resource section. Had to be easy because I could do it. I like red lines and instead of black for the cutout area I filled it with gray. Saved black ink and made the red show up more.. Maybe @Travis could easily explain it or point to the lesson that contains the info,,, or say I am all wet and it can't be done..... John B, OCtoolguy and don watson 3 Quote
don watson Posted August 30, 2018 Author Report Posted August 30, 2018 I have a note of most of the lessons and there may be something there as you say. OCtoolguy 1 Quote
OCtoolguy Posted August 30, 2018 Report Posted August 30, 2018 If you go to go here, it's explained by Steve Good using Inkscape. don watson and John B 2 Quote
Travis Posted August 30, 2018 Report Posted August 30, 2018 You can also open the file in GIMP. Then go to Colors>Colorize. Adjust Hue to the right (or whatever color you want) and move over lightness a bit. You can also play with the saturation slider if you want it a deeper red. John B, OCtoolguy and jollyred 1 2 Quote
Scrappile Posted August 30, 2018 Report Posted August 30, 2018 (edited) Seems like I did it with something at the bottom of the screen. I don't even see any options at the bottom of the screen now when I open it. But when I did it I had Windows version, now I am on a Mac... maybe that is different or an newer version... or,,,, I'm really all wet!! Edited August 31, 2018 by Scrappile Quote
Rockytime Posted August 31, 2018 Report Posted August 31, 2018 I just have Office Max copy my black pattern in red.However all the black is red. Quote
don watson Posted August 31, 2018 Author Report Posted August 31, 2018 Thanks for that Travis. That is what I wanted. Thanks to you other guys who helped out also, it helps to keep the little grey cells working. Don W Quote
