munzieb Posted September 24, 2018 Report Posted September 24, 2018 Wondering if anyone has tried this yet? I'm fairly good at cutting straight lines with the scroll saw but I thought I would try an experiment. I have a project with several long straight lines and laid a straight edge on them and scored them with an exacto knife. If I'm doing better or more complicated projects I use semi-gloss card stock. The exacto knife cuts a good groove. For long thin lines I use a 3/0 puzzle blade and the groove helped the blade track a little straighter. Has anyone tried this method and did it work for them? new2woodwrk, OCtoolguy and meflick 2 1 Quote
Frank Pellow Posted September 26, 2018 Report Posted September 26, 2018 I have tried it, and it did work for me. OCtoolguy 1 Quote
new2woodwrk Posted September 27, 2018 Report Posted September 27, 2018 I have not tried it but now that I know about it I will remember to try that! Thanks OCtoolguy 1 Quote
Rockytime Posted September 27, 2018 Report Posted September 27, 2018 On 9/24/2018 at 2:04 PM, munzieb said: <SNIP> If I'm doing better or more complicated projects I use semi-gloss card stock. <SNIP> I didn't understand about the card stock. What do you do with it? OCtoolguy 1 Quote
munzieb Posted September 27, 2018 Author Report Posted September 27, 2018 8 hours ago, Rockytime said: I didn't understand about the card stock. What do you do with it? Rocky, When I have a larger print to cut, I go to the UPS Store. This print was 14 x17. They have different types of paper and card stock is one of them. It's thicker and the semi-gloss texture allows the dust to blow off easier. 3 of these prints cost $1.03! For high detail patterns I use scrolleronline contact paper. It has the best adheasion but alot more expensive. OCtoolguy 1 Quote
Scrappile Posted September 27, 2018 Report Posted September 27, 2018 I have tried the scoring with the Xacto knife and it does work. Another thing I do along this type of tip, when I have some piece that has "veining" that needs to be cut and I want the kerf to be thicker than a flat blade width, I cut the veins with a flat blade and them re-cut them with a spiral blade. The spiral seem to easily follow the cut line. Much easier than trying to widen the kerf with the flat blade. John B, Frank Pellow, heppnerguy and 2 others 4 1 Quote
Rockytime Posted September 27, 2018 Report Posted September 27, 2018 6 hours ago, munzieb said: Rocky, When I have a larger print to cut, I go to the UPS Store. This print was 14 x17. They have different types of paper and card stock is one of them. It's thicker and the semi-gloss texture allows the dust to blow off easier. 3 of these prints cost $1.03! For high detail patterns I use scrolleronline contact paper. It has the best adheasion but alot more expensive. Thank you. I knew here was something I was missing. Quote
Frank Pellow Posted September 28, 2018 Report Posted September 28, 2018 11 hours ago, Scrappile said: I have tried the scoring with the Xacto knife and it does work. Another thing I do along this type of tip, when I have some piece that has "veining" that needs to be cut and I want the kerf to be thicker than a flat blade width, I cut the veins with a flat blade and them re-cut them with a spiral blade. The spiral seem to easily follow the cut line. Much easier than trying to widen the kerf with the flat blade. Good tip about the wider kerf using a spiral blade. I will definitely try that. Quote
heppnerguy Posted September 28, 2018 Report Posted September 28, 2018 I also discovered the second cut with a spiral and found it worked great for me. When I was visiting with Scrappile a few months ago, I mentioned to him and he told me then that he too, does that. I thought I had discovered something no one else knew about but when I go to Paul about something new, it is always old hat to him. But at least I keep learning things here in the village and from others I am acquainted with. I have never heard about the Exacto knife trick. Wish I would have known about it when I cut my Eiffel Tower, might have been a big help to me. Dick heppnerguy Quote
Woodrush Posted October 2, 2018 Report Posted October 2, 2018 I have also used this with success Quote
ShadowB6 Posted October 16, 2018 Report Posted October 16, 2018 Wow, what a great tip. I will definitely ty doing this. Quote
Woodrush Posted October 23, 2018 Report Posted October 23, 2018 I do it with a pencil and find it works better then the knife Quote
redwine Posted November 21, 2018 Report Posted November 21, 2018 I too have done this but instead of using an Xacto knife I use a marking knife that is made for that specific purpose. The marking knife will not wonder off when it comes to some hard grain. The Xacto thin blade has a tendency to move off line when that happens. Erv munzieb 1 Quote
