Stick your finger in the dirt and it should be moist. Keep the watering consistent or your tomatoes will crack.  Your picture shows you have an extension from the drain of the gutter. You planted right against the house. SOOOO. If you water the plants your putting water against the foundation. Hopefully, you don't have problems with leaks. Something people forget putting bushes, plants against the foundation. The roots will work into cracks of the foundation AND watering plants, your watering your basement.
One trick for tomato plants. Their roots can go deep.. When the plant gets bigger,Cut one side of a pvc pipe at an angle, drive the pvc pipe against each plant and put water in the pipe. It will get the water to the deeper root without soaking a large area. RJF
It's by my garage/shop not my house however.......
