Table higher in back?
Go to solution Solved by Smitty54,
I have mine raised slightly - the height of flat 2x4 (1 3/4).
It does help me see the lines better.
I also use a lighted magnifier which I must say is one of the best accessories I've added to my process
Also, I used to cut my Delta at speed 3. I'm now cutting 6-7  and have much better control and accuracy.
Are you using the DeWALT stand? If so, it is designed so you can raise the rear of the saw. As far as slowing down the saw, I never recommend slowing the saw speed down to the slowest speed. You actually have more difficulty controlling the cut. I recommend you start at about speed 4, then go from there.
It's a matter of ergonomics as much as sight lines.  You want to avoid leaning over too much and you want to get your hands and wrists at a comfortable height to avoid fatigue, soreness, numbness, etc.  How much you tilt the saw will depend on how high your chair is (assuming you cut while seated).  I would suggest raising the back by one hole in the rear leg and see how you like it.  It may take a few tries to get to the ideal place for you, but everyone is different, so it's hard to tell you where that is.  Some folks don't like the saw tilted at all.  You may discover that you are one.
Thanks for the answers and advice. I raised it to the middle setting. I have done my first peace on the 788. I also raise the speed to four. After sanding and painting I will post pictures on bragging rights.
