JimBattista Posted July 21, 2022 Report Posted July 21, 2022 I want to learn to create these type of patterns my self. I have watch Travis's video and I'm pretty much ok up the the point of bridging and then I'm lost. I have cut one of Steve Good patterns for my Daughter-in-law but would like to create my own. Dak0ta52 1 Quote
LabradorBob Posted July 21, 2022 Report Posted July 21, 2022 Select the text you want to bridge,Then select the bezier tool for curves or straight lines. it is about three above the text tool. also go to File,Document properties,then select snap and set the two active sliders to zero for distance. use the bezier tool to draw a bridge,then select the text and the bridge and go to Path,Difference to cut it. Hope this helps, Labradorbob Quote
don in brooklin on Posted July 21, 2022 Report Posted July 21, 2022 I do quite a few of these and I often use the font called scroll script that already has the bridges in it. All so created a template so I just have to put Big word in the Times and the small name in the script and then change to paths. If you want more info please let me know. word in word.svg Scroll_scriptmt.ttf danny, barb.j.enders, jr42 and 1 other 4 Quote
