Flowerflow Posted December 3, 2023 Report Posted December 3, 2023 Hey yall so I am borrowing a friends scroll saw A dremel 1800 and I was in mid use of it this evening and all of a sudden it just stopped working. Now I know that power is getting to it because when it is plugged in the light works on it still But when I have it plugged in and i press the button to turn the power button on I hear a faint electric static then I get freaked out soni turn it of . I believe something electrical is going on with it. Does anyone have any leads on how I can fix this ! Much appreciated, kara OCtoolguy 1 Quote
BadBob Posted December 3, 2023 Report Posted December 3, 2023 Is there any smoke or burning smell? OCtoolguy 1 Quote
Peter N White Posted December 3, 2023 Report Posted December 3, 2023 Have you checked the brushes. OCtoolguy 1 Quote
OCtoolguy Posted December 4, 2023 Report Posted December 4, 2023 Loose wires at the switch? BadBob 1 Quote
Norm Fengstad Posted December 7, 2023 Report Posted December 7, 2023 I have dremel which is parked under a bench, when I used there was always dust in the switch most times I could blow air on it however often had to change the switch. OCtoolguy 1 Quote
kmmcrafts Posted December 8, 2023 Report Posted December 8, 2023 I had a Dremel 1800 back in the day.. I think I had to a power switch in it twice and on the second time I turned it on and taped a cut up latex glove over the switch area and left it on.. that was when I finally broke down and bought a foot switch.. Man.. I can't imagine running a saw without a foot switch now days.. OCtoolguy 1 Quote
Flowerflow Posted December 17, 2023 Author Report Posted December 17, 2023 Hey everyone!!! Thank you so much for replying We discovered that the On and off switch was not computing properly In some tests it would not work at all and in some other tests it was reading the off and on switch occasionally. We Jimmied on a old switch that we had laying around and it is back to perfect working condition. In addition I gave my friend thier scroll saw and got myself a used one off of kijiki so that if it breaks I'm not breaking all of my friends cool stuff ! My challenge now is that I break blades faster than I would like ! Thanks everyone OCtoolguy 1 Quote
Wichman Posted December 17, 2023 Report Posted December 17, 2023 (edited) 3 hours ago, Flowerflow said: Hey everyone!!! Thank you so much for replying We discovered that the On and off switch was not computing properly In some tests it would not work at all and in some other tests it was reading the off and on switch occasionally. We Jimmied on a old switch that we had laying around and it is back to perfect working condition. In addition I gave my friend thier scroll saw and got myself a used one off of kijiki so that if it breaks I'm not breaking all of my friends cool stuff ! My challenge now is that I break blades faster than I would like ! Thanks everyone In the lower right hand area is an arrow showing where I started cutting, in the upper left an arrow showing where the blade broke ( it was worn out, I was expecting the break ), this was at the 25 minute mark, and this is typical for the cutting I do. 1/2" Elm laminated from 2, 1/4" Elm boards. FD Polar #1 blade Edited December 17, 2023 by Wichman spelling OCtoolguy 1 Quote
OCtoolguy Posted December 17, 2023 Report Posted December 17, 2023 19 minutes ago, Wichman said: In the lower right hand area is an arrow showing where I started cutting, in the upper left an arrow showing where the blade broke ( it was worn out, I was expecting the break ), this was at the 25 minute mark, and this is typical for the cutting I do. 1/2" Elm laminated from 2, 1/4" Elm boards. FD Polar #1 blade Beautiful work, Wick. I'd like to try that pattern. Where can I find it? Flowerflow 1 Quote
Wichman Posted December 17, 2023 Report Posted December 17, 2023 1 hour ago, OCtoolguy said: Beautiful work, Wick. I'd like to try that pattern. Where can I find it? This pattern is from the Book Classic Fretwork Scroll Saw Patterns by Patrick Spielman & James Reidle. OCtoolguy and Flowerflow 1 1 Quote
OCtoolguy Posted December 17, 2023 Report Posted December 17, 2023 53 minutes ago, Wichman said: This pattern is from the Book Classic Fretwork Scroll Saw Patterns by Patrick Spielman & James Reidle. I'll look for it. Thx. Flowerflow 1 Quote
Flowerflow Posted December 18, 2023 Author Report Posted December 18, 2023 Very coool. So your saying that potentially and theoretically a blade will break every 25 minutes? By the way that is awesome work it looks tight! !!! During all of that i was working on this snake playing hockey. With the names carved out below. I discovered that I was imagining the name was barff and its actually scarff. So I scrapped the letters. And will have to start again lol Oh cooky cooky fun life OCtoolguy 1 Quote
Wichman Posted December 18, 2023 Report Posted December 18, 2023 4 minutes ago, Flowerflow said: Very coool. So your saying that potentially and theoretically a blade will break every 25 minutes? Nooo, I'm saying that with that blade, in that material I break a blade about every 30 minutes, Your mileage may vary, but it is a reference point. If, you are breaking a blade every 5 minutes there may be a problem, every 60 minutes, then you're doing pretty good. It's the same as how long it takes you to cut out a pattern, it's not a race, but we all want a reference point. OCtoolguy 1 Quote
BadBob Posted December 18, 2023 Report Posted December 18, 2023 Blade breakage depends on too many factors to have a hard, fast rule. I rarely break blades. OCtoolguy 1 Quote
Bill WIlson Posted December 19, 2023 Report Posted December 19, 2023 14 hours ago, BadBob said: Blade breakage depends on too many factors to have a hard, fast rule. I rarely break blades. I agree 100%, except I break blades routinely. OCtoolguy 1 Quote
