this mite not qualify for scroll sawing question but I made this using Steve good pattern site and now I need to figure out how to hang it outside in my friends cemetery
it is made from half inch polywood
4 inches tall 10 inches long
(Remove This Ad)
I'm sorry for the loss of your friend. Before doing anything permanent, I'd check with the cemetery to see what they suggest. They may have rules regarding what can be done. You did a very nice job on that cutting. Your friend would be proud.
My suggestion starts with; get approval first.
Then, build out of metal, a small "two post gable" of an appropriate size. The function of the gable is to keep the sun, and it's UV rays, off the project hung beneath. You may need to do some light research on the overall size and the angle of the gable to keep the most sun off the project beneath. you could make mock ups out of cardboard to test the size and angles before you built the final item. And again, get approval first.
Good Luck
Small Gable Steel Structure 2 Post
