preprius Posted March 11 Posted March 11 I had a need to use a metal cutting blade. I need to cut a metal backer for mounting connector on thin plastic container. i had soft steel strip that I folded over to give me more strength and to match my connector panel thickness. I chose #2 Pegas metal cutting blade. The blades have wider teeth and is harder (more brittle) than wood blade. Yep I broke a blade. Overall it went smoother than I thought. here are some pics... OCtoolguy, Scrappile and Wichman 2 1 Quote
Denny Knappen Posted March 12 Posted March 12 Thanks for the review. I have never used metal cutting blades. OCtoolguy 1 Quote
preprius Posted March 12 Author Posted March 12 1 hour ago, Denny Knappen said: Thanks for the review. I have never used metal cutting blades. Denny, thanks for supplying them. I don't know where my projects take me, so I like to have these on hand. The metal cutting blades did very well. I was about to use the wood pieces in the background to help hold down the metal but never had to. OCtoolguy 1 Quote
