WoodturningVern Posted June 4 Posted June 4 So I have this beautiful piece of maple that I thought I would make into a maple leaf shaped bowl on my lathe. Easy right. I trued it up on the lathe and cut a mounting tenon on what will be the bottom. Then I laid out the maple leaf shape on the top side. That's the dark black line. After that I roughed cut the shape on the bandsaw. The six little holes laid out in a circle are for the mounting flange that I'll attach to shape the bottom of the bowl. The next step is to scroll saw out the maple leaf along the black line. I need to get a pretty good shape now while this is still a blank that is flat on both sides. I double sided taped four small pieces of scrap to the bottom side to give myself a more stable base rather than just trying to hold it on the tenon. The thickness I need to scroll saw out is 1-7/8" and it will be 1/2" raised above the table on the scrap. So, what size blade should I use and what speed on the scroll saw? Any other thoughts? I attached a few pictures of the project. Thanks..... Vern Archer, red river, JackJones and 1 other 4 Quote
TAIrving Posted June 4 Posted June 4 Vern, Looking good so far. I can see where you had your faceplate attached. To answer your question, a #5 blade should work for this. Or even a #7. Practice on a scrap to see what you are comfortable with. Go very gently on the turning. You could snap off the stem or one of the outer pieces of the leave if your gouge should catch. Please show us the bowl when you finish it. Quote
barb.j.enders Posted June 4 Posted June 4 I would use a #5 or #7 skip tooth blade. I would be cutting small sections instead of a continuous line. Start at a point and cut to the next point. (hope that makes a bit of sense.) Quote
WoodturningVern Posted June 4 Author Posted June 4 8 hours ago, TAIrving said: Vern, Looking good so far. I can see where you had your faceplate attached. To answer your question, a #5 blade should work for this. Or even a #7. Practice on a scrap to see what you are comfortable with. Go very gently on the turning. You could snap off the stem or one of the outer pieces of the leave if your gouge should catch. Please show us the bowl when you finish it. I deliberately left the leaf's stem overly large because I was concerned about snapping it off. We'll see what it looks like once I get it shaped into a bowl. I might carve it down the a thinner more realistic shape at that point. TAIrving 1 Quote
Roberta Moreton Posted June 16 Posted June 16 Just as an FYI. A person in our scrolling club cut these out of 3/4” and cut the design on the scroll saw before turning as an experiment. They turned out pretty good! barb.j.enders, Archer and Horseshoe 2 1 Quote
WoodturningVern Posted June 16 Author Posted June 16 Thanks for the insight and pictures of what could be. I'm still fiddling with the saw to make sure I have the capacity to cut them given my blank thickness. I may need to remove the tenon (for lathe mounting) to thin the bank a bit then recut it or a mortise again. It's a process!! Roberta Moreton 1 Quote
