Wow what a shock I was cutting a piece I just turned it off to thread through a new hole, switch it on again and NOTHING.
I Checked the fuse in the plug then checked there was power then I sat down and cried,not really sat down and read the manual hoping for some divine intervention and bam a glass fuse in the side by the plug into the saw.
I decided to pull out the plug to get to the fuse only to realise it was hanging out which blow the glass fuse. So moral of the story when you keep plugging in and out the mains plug make sure the plug is in the saw properly. duh!
What a relief!  Thought I'd share this with you all, don't laugh to much. Roly
Ha Ha, Roly, what a wally. Only joking :lol:  :lol:  :lol:  :lol:
Rob Roy.
Happens to the best of us, If the truth was known there must be some really funny stories to be told from other family members on here. :)
Hey Roly, you're not the only one. Have you ever tried to cut a piece of Padauk with a band saw?, I thought "yes a piece of cake with a nice NEW BLADE". It wouldn't make any impression it. Then I had a closer look. Someone had put the blade in back to front, ie the plain edge facing out. Never did discover "who dunnit".  :cry:  :cry:  :cry:  :cry:  :cry:
Rob Roy
Edited by Rob Roy
Rob Roy
And you called me a wally  :razz:  :rofl:  :rofl:  :rofl: haa haaaaaaa
Rob Roy
I paid Marg to do it to you Rob lol. :razz: :razz: :razz:
Mine is worse than that - I took down the old kitchen cupboard at Dad's to replace it as it was falling apart. I thought if I keep the new mounting holes in line with the old ones I'd be safe - WRONG!!! straight through the mains water pipe with the drill !!! before I could turn off the water it had filled the toaster and meat slicer and flooded everywhere. It took 10 days to get it fixed (they finished 2 hours ago) The plumber asked me who fitted the original cupboard and I said dad, I also added that when I was fitting the new one I thought I would be safe keeping it in line with the old mounting holes. He said normally you would have been, but when your dad fitted the original cupboard he actually drilled between the hot and cold water pipes cutting into both slightly ha added that 1/16" further over in either direction he would have gone through a pipe too. (the gap between the pipes is about1/4") The new kitchen cupboard is now up and mounted on the wall - missing the pipes this time lol.
I think you should have got the professionals in Keith, or maybe Marg 2, she's a dab hand with a screwdriver. :razz:  :razz:  :lol:  :lol:  :lol:
One fine day about 3 years ago I got all of my inside work done and then went out to the garage. I got everything ready to start scrolling and..........DEAD. I changed power points.....DEAD.  :o  So I rang Terry and said my scroll saws not working he says What do you mean its not working I say What part of its not working don't you understand  :curse:  He says Well what have you done I say WHAT DO YOU MEAN WHAT HAVE I DONE I HAVE NOT DONE ANYTHING, OH DON'T WORRY YOU CAN LOOK AT IT WHEN YOU GET HOME.  :curse:  :curse:  He gets home from work and yes he pushes in the side plug and away it goes. :oops:  2 things were learnt that day No1 always check the side plug and No2 NEVER ask me what I have done, because you get your head bitten off. :shock:
Marg
Marg
Wow Marg I'm glad it's not only me then. :D  :D  :oops:
Ya the set on the teeth tend to tear up the rubber on the wheels but how did it get to the bearings? :confused:  :confused:  :confused:
The rear support bearings which support the back of the blade  as you are cutting. Unfortunately this time it was the toothed side of the blade which was running on the bearings. Made one Heck of a mess of the blade, I'm surprised it didn't snap. Expensive lesson learned Danny. :cry:  :cry:  :cry:  :cry:  :cry:  :cry:  :cry:
Rob Roy
Rob Roy
bet you never saw that coming.  :lol:  :lol:
