I was given a Red Oak Burl that I cut into seven pieces.
Each piece is approximately 18 inches wide and 7 inches tall.
Thickness is from 1/2  to 1 + inch thick.
The grain is most outstanding and unusual.
I am perplexed as to what to do with them.
This is a picture of one piece front and back.
The grain changes throught the face of the board many many times.
I'm Awed by it.
One small section where the bark fell off looks like a topographic mountain scene.
With streams and rivers cascading down. My wife took a magnifying glass and
spent 15 minutes looking at it.
Almost hate to cut any of them. Maybe just polish and put a finish on them.
Though I guess I could sacrifice some of them to some type pattern.
Finish a couple as is ,One day out of the blue you will see ,something that you never saw before and you will ,have your projecct , they are special and require a special unique project ,resin loaded ,multidirectional grain and usually harder then bejesus ,blade loading and eating but in the right project elequant .Thats is just one of the reasons they are special !
Larry, I can't see them that well. Could you send them to me for a closer look? Hehe. I agree with the clocks. They would also make great pens. Even sand them well and put a nice finish on one and place it on the mantle as a back drop for a candle.
I would bore a hole and make clocks out of them.   I will take one or two and add a clock. Danny, how would you finish them?
 I agree and I will finish a couple and three or four will sit. What finish would you use?
Ever try spray wax?
Lacquer is fast and easy to work with but has a harsh odor. My wife won't let me use it in the basement. I found that Minwax poly spray works fine and additional coats go on nicely after the previous coat set for only 30 minutes. It does require sanding with 300 grit after the final coat but has no harsh smell.
Wow, That's good looking wood. I would make a hollow spiral lamp from something that nice. With wood like that I would use Odies Oil for a finish, great stuff. This oil is put on with a rag or a scotch bright pad. Wait 30 min. apply 2nd coat and buff. Dries hard and can be repaired if needed.
Edited by grosa
