I agree.  Looks awesome.  I saw your post on the Intarsia Nuts Facebook page yesterday. (I don't have Facebook account so couldn't post there to tell you looked great.)  I was amazed at the detail in it.  You did a great piece and I am sure that your coworker and her boyfriend will be extremely pleased with it.  Thanks for sharing the pic of your work over here.
Wow I just started working on the same one two days ago!
Looks good so far. The wood choices look good. How are you going to texture the mane? I don't have a wonder wheel like Judy uses. I used a cut off wheel  for a dremel with a flex shaft on it. Be sure to post the finished project.
Beautiful piece, one heck of a gift. I hope she puts that into a pre-nup agreement incase the they part ways. :)
All kidding aside The detail, fit and shaping are perfect. I assume you used the wonder wheel for the fur. I picked up a new one last year when Judy was at the Fox Chapel open house. It is harder than the original and holds its edge longer.
For those of you using a dremel an alternative is a small v groove carving tool, very sharp and watch grain direction. Monsterat the white looks like Aspen unless it is hard.
there ya go...  I decided not to detail the mane
Looks great both ways, both with the detailing on the mane like jscottj did or here, without it that you did. Thanks for sharing your photos as well. As a newbie, I enjoy seeing others Intarsia work to see how others approach it.
I don't own a wonder wheel yet. I used a cut off wheel for a dremel with a flex shaft on it using it to grind a groove sorta like the wonder wheel does. I have a couple of dremel carving bits, but find them hard to keep from drifting /pulling in the spring wood to summer wood changes in hardness. Practice may help with that though.
