Ok I have been looking at bandsaws for a while. I was looking at a 10 inch but want more resaw capacity. I am also looking to not break the bank. I am looking at a Rikon 10-324. It has a 13 and 5/8 throat and 13 inch resaw. All bearing construction and blade guids. A standard blade at 111 inches. I can get it shipped for $760. Does anybody have experience with this saw?
Lucky you,i have great need for a saw that can resaw.
I thought the same thing when I bought my Grizzly 14" with riser kit etc.. Those thoughts changed once I realized how much time it takes to resaw and plane boards to size.. my time is worth money at the scroll saw.. not being a sawmill, LOL.. Maybe I am just lucky to have a brother with a sawmill just up the road from me.. and my uncle has once right next door.. someone always has a board that I need ready made.. other than I do run it through my planer to smooth it out..
I only have experience with the grizzly saw.. but just wanted to say that  the price seems pretty good for the rikon.. I had about that much into mine by the time I bought the extra goodies like riser block resaw fence etc etc..
The comments about resawing is right on point.  Resawing a 5-6" board is not too bad but you still need to run it through a planer afterward.  Also, it takes some skill and time to learn to set up a band saw to do the resaw.  And blades,are not cheap and they have to be sharp.
I am not saying that it can not be done but not as easy as it sounds.  Even I have done it but not on real wide boards.  There are some who can make veneer by resawing and I am very jealous of their skill.
Most of my resaw in will be logs. I am wanting to cut the heart to keep the wood from splitting for making blanks for my lathe. I was also wanting to cut some thin rounds for doing fretwork in. None of it is for finish work. I'm sure I will find other uses once I get it.
I found that since I don't like the time to resaw.. that I found I like making bandsaw boxes.. hopefully can make and sell some to help offset the reasoning / price for the bandsaw in the first place.. since I bought it with the intent to resaw..
I have the Rikon 14 inch it has been a learning curve but I am better than when I started. I have made few bandsaw boxes but not good at it so far. at the shows those guys make it look easy and fast. for me not easy not fast. The saw how ever has served be well so far
The blades used makes the world of difference... just sayin.. just like scroll saw blades.. the ones that are ready made in the stores... they're junk..
If you are going to resaw with a 14-inch bandsaw, then take a close look at the Timberwolf 3/4 inch blades. These are the blades that are .025inch thick. Most 3/4-inch blades are .032 inch thick and do not bend well around a 14-inch wheel.  If you are resawing small boards then a 1/2-inch or 5/8-inch blade will work.
For bandsaw boxes, I've had the best results using a 3/16-inch blade backed by a Carter Stabilizer wheel. That's what I've watched Alex Snodgrass and the demonstrators at the shows use when they cut the boxes or those little reindeer figures.
Yeah, those timberwolf blades are what I use.. Awesome blades...fast cutting etc..
Buy mine from P.S. Woodmachines..
Edited by kmmcrafts
The Rikon is a good saw. I have the Shopfox. It has a 1hp motor. I recently purchased the riser for it so I can re-saw. I have not had any trouble re-sawing at all. In fact, I look at it as a challenge, part of the woodworking experience I guess.
$699 is a great price. You'll love the saw. Have fun with it.  When re-sawing, three words of advice, take....your....time.
