Hello all,
I tried something new to me, making a color break with paduck and yellow heart.  I sanded them together to make it look like one piece.  However I can't seem to get the orange dust out of the dep yellow heart grain.  I've tried a damp towel and even light sanding.  Ant tips to remove the dust?
Thanks
When I'm shaping multiple pieces on a sanding shim, I use a heavy grit (80 - 100) to get the basic shape, then switch to a light grit (220) for a final shape. Then I break the pieces off the shim and give each piece a final swipe with the light grit and run it through a sanding mop (220-320 grit).
That usually knocks any sawdust bleed over right out and it looks fine.
Thanks for the tips.  Looks like I need to get a few more tools.  I just have a 1" belt sander I use for the basic shaping.  The finest I can find is a 120 grit.  I then hand sand with 220, 320 and finish with 400.  It takes a long time, but I like the results.
Try https://www.woodworkingshop.com/abrasive-belts/ or http://www.supergrit.com/products/products_belts
They have belts with grits down to 1000.
If you want a new toy - go for a slow speed grinder and some flex-drum sanders. You find them versatile as heck when shaping intarsia. Woodcraft has a Rikon 8-inch that they put on sale for $99.95 every now and then. The flex drum sanders are from Judy at intarsia.com or Ray at SeyCo.com.
