Foxfold Posted August 11, 2019 Report Posted August 11, 2019 I tried cutting a piece today that needed a 'finer' blade than my normal go to blade (#3) - so I chose the next one down (#2). Now,, I liked the fact that it has a much smaller kerf, however, I find it difficult to make it go where I want it to go as it has a tendency to 'wander. Now, is that because I'm not experienced enough with this blade - should the tension be tighter than with a larger blade - does it need to have the saw running at a slower/faster speed ? Questions, questions !!! All because I don't have enough knowledge Any assistance gratefully received. OCtoolguy, amazingkevin and don watson 3 Quote
fredfret Posted August 11, 2019 Report Posted August 11, 2019 I add tension when I reduce blade size. I also reduce speed either feed or saw speed for additional co trol OCtoolguy, don watson and Foxfold 1 2 Quote
dgman Posted August 11, 2019 Report Posted August 11, 2019 I always keep a high tension no mater what size of blade. I see no reason for lower tension on smaller size blades. OCtoolguy, amazingkevin, Foxfold and 1 other 2 2 Quote
jollyred Posted August 12, 2019 Report Posted August 12, 2019 When I have problems with the blade following the line, I will concentrate on the line going into the blade, not the blade following the line. I also slow down some, and sometimes set a lower speed on the saw. Other times, I just go into the house and sit down with a good book. OCtoolguy, don watson, John B and 2 others 1 1 3 Quote
JTTHECLOCKMAN Posted August 12, 2019 Report Posted August 12, 2019 The smaller the blade the thinner the metal of the blade and that is what wanders on you. You have to slow the feed rate somewhat but the difference between those two sizes should not be drastic unless they are different brands. Do not reduce tension. amazingkevin, Foxfold, don watson and 1 other 1 3 Quote
JimErn Posted August 12, 2019 Report Posted August 12, 2019 Along with what everyone else has said, it can be the blade. I have that problem with FDUR #3, as soon as I changed to Pegas MG #3 I had no problems with the blade wandering. OCtoolguy and Foxfold 2 Quote
kmmcrafts Posted August 12, 2019 Report Posted August 12, 2019 I found that just drawing a new line where your blade went works real well... makes it look like you went where you were supposed to go.. I believe you need to slow down your saw speed for a better control.. Those real small blades will flex easier and if you push too hard on the piece it'll flex the blade.. They can be like a spiral blade to an extent where they will try to wonder into the easier cutting wood.. they'll drift into softer grain..especially cutting in the same direction of the grain.. amazingkevin, don watson, John B and 2 others 2 2 1 Quote
LarryEA Posted August 13, 2019 Report Posted August 13, 2019 #2 and #3's etc are not generic. THey also come in different sizes, TPI etc. Get a different #2. amazingkevin, Foxfold, don watson and 1 other 3 1 Quote
