Hi All,
I just rearranged my shop and set up my Dewalt scroll saw to use along with my hegner and I thought about gettting a wall mount dust collector for that purpose. Anybody use one and recommend brands etc. Will they really pick up the dust? I have a jet on my ceiling and run that also, but I get that fine dust from my bb plywood.
Thanks
Bill
Personally, I think a shop vac is better for a scroll saw than a dust collector.  A dust collector has a hugely lower vacuum than a shop vac.  A dust collector has up to 10" of vacuum while a shop vac is typically over 60" .  When going thru small pipe or hoses this will be important.  A dust collector is great for larger sizes hoses like a 4" hose.
 I have a powerful dust collector that does not do very good on small hoses on my scroll saw.  But a shop vac does much better.
Hi
Thanks for the answers, I am hard of hearing and wear 2 aids and if I use a shop vac then I have to wear headphones and take hearing aids out. I don't know if I want to do that, also wouldn't a shop vac get awful hot if your running for like an hour steady? I might try my 1 hp vac on it and see. I am not spending 500 dollars for a quiet shop vac either. I thought shop Vac made a quiet one but I can't find it at Menards or Wally mart
Thanks
Bill
1 hour ago, nrscroller said:
Hi
Thanks
Bill
Get yourself one of those outlets that will trigger your shop vac when you run your saw. You can either make one or buy one for about $40. My Fein vac has that built in. I bought it used on Craigslist for $175. Very quiet compared to my Ridgid vac.
Edited by octoolguy
