With the new projects about to start, and almost being able to empty the garage, I re-ran the hoses for my main dust system (the HF 2hp)
Here is the old run:
From the corner to the ceiling
then down the other end of the work table then up to the scroll saw and then
over to and up to the table saw
It worked, but it was also my first set up
I then had my shop vac hooked up to the scroll saw with my DD (Oneida) - it was fine, but inconvenient and it was the only thing running with the shop vac
Now, it goes from the corner up to the ceiling and down to the scroll saw and the table saw leaving the shop vac no longer part of the equation
Less turns, and took out about 25' of hose
It will also be easier to run a connection to any rolling carts if I want or just hook up the shop vac that is no longer hooked to the scroll saw
I don't really have the correct connectors, but I make do with what I have (lots of pvc, hose and 2" gates) and it works and no air escapes.
Thanks as always for reading
Edited by new2woodwrk
  • 3 weeks later...
7 hours ago, Chiloquinruss said:
I use regular hard pvc with flex on the ends.  Seems to work ok for most of the tools.  Still trying to get a better dust system for the scroll saw though.  It's a tricky situation as the scroll saw is such an open area tool! 😀 Russ
Wow, now that's a work shop!
Once I get the shop redone, I'll have to rerun everything again. I may bite the bullet and go with pvc - not sure yet since the garage is still a complete mess\
  • 2 weeks later...
Thanks for the kudos gang, BUT . . . . . . . My face is red by posting such a miss leading pix!  It hasn't looked that CLEAN is quite awhile!  🙂  I don't do big jobs anymore so I don't always do a good clean up after each little job.  Sooooo, the little job clean ups gather, and then it's a major clean up job!  I should go out to the shop and show you the current state of disarray!  😳  Functionally it still works as far as the layout goes but a bigger shop is not necessarily the answer for the 'mess' situation!  😀  Thanks again for the kudos I appreciate it!  Russ
Do you use a scooter to get around the shop???
I used to wear myself out but I have since learned to get three of any tool I need.  I have one set at each end of the shop and I have a set in the middle of the shop!  😀  I find that really cuts down the 'traffic' flow!  I also have multiple stools and some heavy floor pads by most machines.  The hardest part is most of today;s modern machines have NO cup holders!  🙄  Russ
