Paul hd Posted June 10, 2020 Report Posted June 10, 2020 Would it be possible to make this into a pattern please. Quote
jollyred Posted June 11, 2020 Report Posted June 11, 2020 Here is one attempt. It will print out at 10" high on letter size paper. Any other size is up to you. The dashed lines would probably be painted, but could be cut. Tom CARE AFTER COMBAT.pdf multitom and ChelCass 1 1 Quote
Paul hd Posted June 11, 2020 Author Report Posted June 11, 2020 Hi Tom, Many thanks for your time. I was after something that I could cut and then maybe add colour on a background board. But I am hoping to have a pattern that could just be cut without adding colour. Kind regards, Paul. Quote
jollyred Posted June 11, 2020 Report Posted June 11, 2020 7 hours ago, Paul hd said: a pattern that could just be cut without adding colour. Is this what you want? CARE AFTER COMBAT 01.pdf CARE AFTER COMBAT 02.pdf Quote
heppnerguy Posted June 11, 2020 Report Posted June 11, 2020 HERE is something a little different and should you decide to color it, I think you would find that part really easy and although a little challenging to cut, depending on how long you have been a scroller, I believe you would enjoy the results. Should you try this one keep in mind that the outline is to end up as one solid piece and the inside pieces have to be replaced between the outline, once they are painted and them they are all glued to a backer board. I would suggest it is cut from 1/4 inch material and I would use a #1 or smaller blade. I would use as small a drill bit as possible for this to come out. If you drill the starter holes within the boarder parts and paint the boaders black, they should not show with finished. I also uploaded the Dumbo plaque I did in this manner so you can see the results of doing it this way Dick heppnerguy frankorona and multitom 2 Quote
Paul hd Posted June 11, 2020 Author Report Posted June 11, 2020 Thank you Tom & Dick, I have to get my head around these patterns. Quote
heppnerguy Posted June 12, 2020 Report Posted June 12, 2020 3 hours ago, Paul hd said: Thank you Tom & Dick, I have to get my head around these patterns. I will go ahead and do the sign one so it is cutable also. frankorona 1 Quote
