LarryEA Posted December 11, 2020 Report Posted December 11, 2020 I have a project that requires very small blades. Recommendations and suppliers please. Cutting a stack of three BB or lauan plywood Thank you amazingkevin 1 Quote
don in brooklin on Posted December 11, 2020 Report Posted December 11, 2020 The smallest blades are jewelers blades all the way down to 3/0. Not sure about 3 - 1/8 I have used he puzzle blades and they work well. I get my blades from https://mikesworkshop.com/ LarryEA and amazingkevin 2 Quote
LarryEA Posted December 11, 2020 Author Report Posted December 11, 2020 The smallest blades are jewelers blades all the way down to 3/0. Not sure about 3 - 1/8 Don, how do they do cutting wood? Quote
Scrappile Posted December 11, 2020 Report Posted December 11, 2020 I use #1 Pegas Skip Tooth for 1/2" and below wood.... Order them from Denny at https://www.artcraftersonline.com Just placed an order yesterday. amazingkevin 1 Quote
Rockytime Posted December 12, 2020 Report Posted December 12, 2020 2 hours ago, LarryEA said: The smallest blades are jewelers blades all the way down to 3/0. Not sure about 3 - 1/8 Don, how do they do cutting wood? Actually they go down to 8/0. amazingkevin 1 Quote
Roberta Moreton Posted December 12, 2020 Report Posted December 12, 2020 How thick are the layers? Quote
LarryEA Posted December 12, 2020 Author Report Posted December 12, 2020 (edited) 2 hours ago, Roberta Moreton said: How thick are the layers? 1/4 inch each = 3/4 " Correction....5/8 inch Edited December 12, 2020 by LarryEA Quote
Scrappile Posted December 12, 2020 Report Posted December 12, 2020 You said 1/8" in earlier post.... let us see what you are wanting to cut and maybe we can help more... although, blade makers, size, vender, are personal preference.... amazingkevin 1 Quote
LarryEA Posted December 12, 2020 Author Report Posted December 12, 2020 1 hour ago, Scrappile said: You said 1/8" in earlier post.... let us see what you are wanting to cut and maybe we can help more... although, blade makers, size, vender, are personal preference.... Made me go measure... three ply thickness is ABOUT 5/8 inch total.. Is that about 3/16 each Quote
FrankEV Posted December 12, 2020 Report Posted December 12, 2020 I use Pegas #2/0 Mod Geometry R blades and #2/0 Spiral blades for much of my really small intricate detailed work including stack cutting up to 1/2" (4 layers of 1/8", or 2 layers of 1/4" Ply). #0 and #1 blades are still relatively small blades and will work better where possible. I'm in the process of cutting some full 3/4" solid poplar using Pegas #1 spiral blades right now and there is no poblem (as long as you don't kink the blade ). Highly suggest you choose BB ply over Luan. Luan will not produce good result for small details, Surface grain is very large and will not sand or take a finish well either. If you are not purchesing you panel material on-line, Home Depot does carry 2'x4' sheets of 1/4" BB ply that looks nice. I just looked at some yesterday. Order Pegas blades from https://www.artcraftersonline.com HTH amazingkevin and LarryEA 2 Quote
nrscroller Posted December 14, 2020 Report Posted December 14, 2020 Hi I use the pegas 2/0 blades for all my work and they are good for smaller items, making bend and corners etc. Bill LarryEA 1 Quote
LarryEA Posted December 14, 2020 Author Report Posted December 14, 2020 2 hours ago, nrscroller said: Hi I use the pegas 2/0 blades for all my work and they are good for smaller items, making bend and corners etc. Bill Thanks, I did order the Pagus 2/0's Quote
Sparkey Posted December 19, 2020 Report Posted December 19, 2020 I stack cut three layers of 1/4” and use mostly FD New 3/0 spirals. They cut pretty small. Quote
