Popular Post yamatetsu Posted June 29, 2025 Popular Post Posted June 29, 2025 "Wacky Races: Dick Dastardly & Muttley" 46 x 40cm, backer board 4mm, Dick & Muttley 4mm, Dick & Muttley backer boards 4mm thick, 'cheap' DIY store ply, done with a hand held fretsaw with a #1 blade. Charlie E, New Guy, Dan and 9 others 10 1 1 Quote
Scrappile Posted June 29, 2025 Posted June 29, 2025 Is that segmentation? Very fine detail. Great cutting. yamatetsu 1 Quote
yamatetsu Posted June 29, 2025 Author Posted June 29, 2025 (edited) 1 hour ago, Scrappile said: Is that segmentation? Very fine detail. Great cutting. Yep. I start by cutting two boards to the exact same size, one to be the bottom layer, the other, the top. I then cut the first piece. When that's done, I paint it completely, except for the bottom. I set that one aside to dry. While the first piece is drying, I cut and paint the next one. After three or four pieces, the top layer has basically become a template. I put that template on the bottom layer, aligning them perfectly. Now, to glue my pieces to the bottom layer, I just have to plop them into their respective holes and then gently lift the top layer to avoid getting it glued to the bottom layer accidentally. Rinse and repeat. Edit: This is a special case, since Dick Dastardly and Muttley are basically two separate pictures. So I made three backer boards, the big one I glued Dick & Muttley on, and a backer board for Dick & Muttley each. I then made two top layer boards. I used double tape to tape the backer boards to the top layers and then cut out Dick & Muttley's shapes out of the two boards. So I ended up with two backer boards in Dick & Muttley shape and two top layers in the exact size & shape. From this point on I used the process of cutting and glueing the pieces to finally get Dick & Muttley on their backer boards, which I then glued on the big backer board. Edited June 29, 2025 by yamatetsu FrankEV and Scrappile 1 1 Quote
FrankEV Posted June 29, 2025 Posted June 29, 2025 Very well done. How do you paint? Looks too smooth for a brush especially on cheap ply. Is the black limes following the joints? Quote
yamatetsu Posted June 29, 2025 Author Posted June 29, 2025 1 hour ago, FrankEV said: How do you paint? Looks too smooth for a brush especially on cheap ply. I use a brush. Small pieces I can give that smooth look, larger pieces sometimes don't look that good, those I work over with a foam roller. 1 hour ago, FrankEV said: Is the black limes following the joints? The backer board is painted black. So by glueing the painted pieces to the exact places where they belong, the black lines are created automagically because they are the only pieces of the backer board that are still visible. FrankEV 1 Quote
rjweb Posted June 29, 2025 Posted June 29, 2025 Looks great, thx for explaining your process, RJ yamatetsu 1 Quote
Gonzo Posted June 29, 2025 Posted June 29, 2025 Looks great! Wacky Races, I loved that cartoon. You should do one of the character Penelope Pitstop. yamatetsu 1 Quote
wombatie Posted June 30, 2025 Posted June 30, 2025 They look amazing. Excellent work. Marg yamatetsu 1 Quote
