I am using a GVS P3 respirator (I don't know if it's the better choice) and I have two questions related to it. Maybe some of you using this respirator (or similar) can give me a hint:
- GVS recommends changing the filter every 30 days for a kind of intensive use. It's not my case. How do you know when you need to change the filters? Can you gently vaccum them to clean them a little bit?
- Do you desinfect in some way the respirator after every use? I clean it with water from time to time, but I am afraid of mold or invisible bacteria forming because of humidity when breathing through the respirator. If so, what do you use for desinfection?
Thanks for your answers.
(Remove This Ad)
As you say... the dust might be the least of your worries with using these due to mold and bacteria. I got pretty sick once with something respiratory.. doctors had no clue but put me on antibiotics and cleared it up.. next week working in the shop I got it again.. I think there was something in my filters of my dust mask.. Ever since then I started changing my filters more often than not.. they're cheaper than a doctors visit and not being sick is always a big plus... I'm not sure I'd even bother trying to "clean" to prolong the life of something like this.. as I said.. filters are cheaper than the office visit so I would just change the filters or replace the mask.. your health is worth it.. Probably safer to not even wear a mask if you're not going to change out the filters and breath clean air what's the point.
I use the Gerson ( Harbor freight ) mask. I bought the "disposable" mask ( the filter are fixed on the mask, but the tabs can be broken and replaceable filters can then be attached, all the proper lugs are there, so it's not just a jury-rigged thing ). I use VOC filters with a P95 prefilter, I change the prefilter when I can see a color change or if I can see dust on the shroud that keeps the prefilter in place; I change the VOC filter if it becomes difficult to pull air through or if I can feel a change in the filter ( sinus or allergic reaction ). If you want to disinfect the inside of the mask, use either an alcohol wipe or a dust free cloth with alcohol on it ( my local Family Dollar store has 91% alcohol ); that what we used on our gas masks in the military.
I was not sure if alcohol could damage the rubber, but it worths a try. The worst thing it can happen is that I should by a new mask.
