(Remove This Ad)
What in the world are we looking at. This saw has some mileage on it. What tray? All that foam is rediculous. That is not stopping vibration of any kind. Put some rubber pads under the feet of the saw. Clean that up. I see you use a aquarium air pump for dust removal. How is that hooked in your circuit. ?
Edited by JTTHECLOCKMAN
Ditch the foam.  Bolt it directly to the bench and make the bench HEAVIER and be sure the bench is as RIGID/STIFF as possible.  Nearly all saws have speeds they run smooth at and buzz or vibrate at.  The simplest fix is a solid bench and weight - not loose weight either.  Bolt everything together securely.
  • 2 weeks later...
