Howdy.  I got an email from someone who had a pattern making question.  Tonight I'm going to put together a quick video tutorial for them.  I figured if anybody else had a question on using Inkscape, I can quickly cover that too.  It's more of a "How do I __________" type of question.  So if you have a burning Inkscape question, post it below and I'll see if I can cover it in the video.
Travis,
Can you explain how to take letters from a word as individual items.?
take care
Don W
Sure thing.  Check out the second video in this article.  The process is called Breaking Apart.
Breaking Apart
After typing your text, you can break apart the letters and move them around individually. This gives you the most control over the placement of the lettering. You can break apart individual letters into their separate shapes. This is useful when dealing with the dot of an i or j.
Type your text in choice of font.
  • Go to Path>Object To Path. This will change your text into a collection of objects. It still looks like one large object instead of a collection of objects because they are grouped and treated as an object.
  • To ungroup, go to Object>Ungroup. Now each of the letters are its own object.
  • Deselect all the objects. Then select one of the letters and position or alter them as needed.
  • Once all the letters are in place, select all the objects and go to Path>Union to weld the letters together.
Thanks Travis,
I was looking for a way to take the letters from a picture.
I have a logo I want to manipulate and I was wondering if I could copy the letters and cut them from the background.
I am having a problem trying to put a picture here so I will leave it for a while.
Thanks again
take care
Don W
HI Travis
I just downloaded version 48.4 as I had to do a complete refresh on my computer.
Now the toolbar is on the right side.  Can this be put on top like before or can you modify the icons.  I like the align and distribute easily available.
Can I bring up align and distribute with hot keys.
Thanks
Don
  • 4 months later...
