Dan Posted April 17, 2016 Report Posted April 17, 2016 (edited) Ok, it's actually my second. I'll tell you about the first later. This is ambrosia maple a guy at work gave me. I used a 1/4" blade to cut it. It measures 5-1/2" x 3-1/4" and is 3-3/4" deep. Sanded on the belt sander and spindle sander then by hand. Finish is BLO/mineral spirit. I still have to let the last coat cure then I'll buff it out. I will also flock the drawer. These should be called sand boxes because of the amount of time spent sanding. Now, about that first box...after cutting and gluing and sanding I put the drawers in and realized a fatal mistake...I cut the cavity in the drawers on the bottom. Yikes! Well, at least that one was some cheap poplar. Edited April 17, 2016 by Dan amazingkevin, Jim Finn and woodknots 3 Quote
Phantom Scroller Posted April 17, 2016 Report Posted April 17, 2016 Dan that is some beautiful wood on your first try we'll called the other a practice piece. Roly woodknots 1 Quote
Scrolling Steve Posted April 17, 2016 Report Posted April 17, 2016 That turned out great Dan !....Love that wood ! woodknots 1 Quote
New Guy Posted April 17, 2016 Report Posted April 17, 2016 Nice one You will be making more when people see it and want one. woodknots 1 Quote
woodknots Posted April 17, 2016 Report Posted April 17, 2016 Nice work Dan. I've been meaning to give it another try. My first attempt was not successful it was before I got my scroll saw. Quote
Paul hd Posted April 17, 2016 Report Posted April 17, 2016 Excellent work Dan. The Maple looks amazing too. Quote
don watson Posted April 17, 2016 Report Posted April 17, 2016 That looks a beauty Dan. Could you not sell the 'practice' piece to an Australian ? Quote
amazingkevin Posted April 17, 2016 Report Posted April 17, 2016 (edited) Ok, it's actually my second. I'll tell you about the first later. This is ambrosia maple a guy at work gave me. I used a 1/4" blade to cut it. It measures 5-1/2" x 3-1/4" and is 3-3/4" deep. Sanded on the belt sander and spindle sander then by hand. Finish is BLO/mineral spirit. I still have to let the last coat cure then I'll buff it out. I will also flock the drawer. These should be called sand boxes because of the amount of time spent sanding. Now, about that first box...after cutting and gluing and sanding I put the drawers in and realized a fatal mistake...I cut the cavity in the drawers on the bottom. Yikes! Well, at least that one was some cheap poplar. I'm thinking that my mini band saw with a 1/2" blade will not turn tight enough to make a box .what size blade do you use on your band saw?Very decorative wood you have here.! Edited April 17, 2016 by amazingkevin Quote
Dan Posted April 17, 2016 Author Report Posted April 17, 2016 Thanks everyone. Don, I think you are on to something. I was thinking of sending it to the international space station. I guess things wouldn't fall out there. Kevin, I used a 1/4" blade. I broke my 1/8" blade and couldn't find one locally so I have to order one. Quote
Rob Posted April 17, 2016 Report Posted April 17, 2016 Lovely box Dan and stunning piece of timber. Rob Quote
dgman Posted April 18, 2016 Report Posted April 18, 2016 Great looking box Dan! It's amazing what beatle turds will do! Quote
Lucky2 Posted April 19, 2016 Report Posted April 19, 2016 Kevin, in the pattern books the recommended size of blade to use is 3/16", it turns better than the 1/4" one does. Len Jim Finn 1 Quote
Dan Posted April 25, 2016 Author Report Posted April 25, 2016 Here's the finished piece. I flocked the inside of the drawer. I also added some stick-on felt to the bottom of the case. This made it very quiet to slide in and centered the kerf to give it a better finished look. I added a small rubber bumper to the back so when it is pushed in the drawer is flush with the case. Travis 1 Quote
Jim Finn Posted April 28, 2016 Report Posted April 28, 2016 (edited) Wow! Nice job and great choice of wood for it. I also have recently made my first band saw boxes and after making a few, I stopped using a borrowed spindle sander and started using pneumatic drum sanders on my drill press. Works way better for me. I found the spindle sanders' hard drums were hard to control. I kept getting wavy surfaces from them. I have a 3"drum and a 1 1/2" one. The softer pneumatic drum avoids this wavy surface problem. They are kinda' expensive though. I settled on using 5/16" blade and making my cuts to fit my smallest drum. 1 1/2" To reduce the sanding required I found that minimal sanding on the inside of the box and the inside of the drawers worked well enough because I flocked these surfaces. Dark brown flocking covers a multitude of sins, makes the drawers slide quietly and smoothly also. It also aids in getting the reveal around the boxes even. This flocking idea was not original with me. I saw it in an on line video. Be cautious, band saw making can be addictive. Edited April 29, 2016 by Jim Finn Quote
Dan Posted April 28, 2016 Author Report Posted April 28, 2016 Thanks Jim. I just received my 1/8" blade and will order the Carter blade stabilizer this weekend. I may try flocking the inside of the box where the drawer slides next time. I've been thinking of getting a pneumatic sander so this may also happen this weekend. Jim Finn 1 Quote
FranMike Harley Posted April 29, 2016 Report Posted April 29, 2016 Awesome, Dan !!! Nice work and love the color .. Quote
