Pictures in wood Posted February 15, 2020 Report Posted February 15, 2020 I would like to know everyone's opinion on the wonder wheel? amazingkevin 1 Quote
don in brooklin on Posted February 15, 2020 Report Posted February 15, 2020 I have one and it is great to add texture to intarsia. Feathers, fur, etc. I don't do a lot of intarsia but it is on my todo list. Judy has a couple of videos on using. It takes a bit of practice not to burn the wood. You also have to make sure the you true it up with a dresser to a point. https://youtu.be/kQXL-wcquX4 Judy has a couple of videos on using. Note light touch. Easier said then done. https://youtu.be/QCHXawMBG4k https://youtu.be/EHR-Obj59ak amazingkevin 1 Quote
JimErn Posted February 15, 2020 Report Posted February 15, 2020 Don, what does the wonder wheel appear to be made of? I looks as if it is a very fine grinding or polishing wheel. In that one video it looks like that is a diamond sharpening stove being used to dress the wheel. thoughts? Quote
planeur Posted February 15, 2020 Report Posted February 15, 2020 Jim, as you , I am interested in that wheel so as you probably saw , I just found that information from JGR https://intarsia.com/pages/wonder-wheel-help planeur JimErn 1 Quote
tgiro Posted February 15, 2020 Report Posted February 15, 2020 The JGR Wonder wheel is a 1/2" thick fiber metal polishing wheel. It has some abrasive material in it. Judy has them made specially for her. You can find wheels like that at Grainger or McMaster Carr, but they will be 1" thick. The wheels work best spinning at 3600 RPM. You "sharpen" the edge of the wheel to a fine point, using a diamond wheel dressing tool. I use the wheel to cut fur texture into animals, grass texture into landscape, needle texture into pine boughs - things like that. A while back, I put a post in the WIP forum, making a Koala bear project. At the end of it I have some explanation of how I used the Wonder Wheel to add the fur texture -- I was going to add Judy's Wonder wheel link but Planeur beat me to it GrampaJim and JimErn 2 Quote
JimErn Posted February 15, 2020 Report Posted February 15, 2020 Tony, thanks so much, that was an excellent tutorial. I understand that Judy sells the wonder wheel at a 1/2" thinckness, but does it really matter? I mean if you are going to dress it to a wedge shape anyway it would just mean a different angle. Hmmm would waste more of it though during the dressing, so I guess it might depend on price Judy vs another that is thicker. amazingkevin 1 Quote
Rolf Posted February 17, 2020 Report Posted February 17, 2020 You would be surprised at how tough the wheel is. Shaping a thicker wheel to the edge that you want would be tougher on a thick wheel. I really enjoy the capabilities that the wonder wheel gives me. amazingkevin 1 Quote
Bpardue Posted February 17, 2020 Report Posted February 17, 2020 I bought the wonder wheel when I 1st started and did not care for it. I have better control by using my power carver and a cutoff wheel that way I can see what I'm doing. it is just easier for me planeur and amazingkevin 1 1 Quote
JimErn Posted February 17, 2020 Report Posted February 17, 2020 10 minutes ago, Bpardue said: I bought the wonder wheel when I 1st started and did not care for it. I have better control by using my power carver and a cutoff wheel that way I can see what I'm doing. it is just easier for me I wondered about that aspect, I watched the video's of using the wheel, and while she made it look easy, I'll bet it takes time to learn it, with a lot of oops events. I'm not there yet, needing that kind of texturing I mean, but who knows Quote
tgiro Posted February 17, 2020 Report Posted February 17, 2020 3 hours ago, JimErn said: I wondered about that aspect, I watched the video's of using the wheel, and while she made it look easy, I'll bet it takes time to learn it, with a lot of oops events. I'm not there yet, needing that kind of texturing I mean, but who knows Actually, the Wonder wheel is an easy tool to use. While I have used it for leaf veining, I don't try to drag long lines with it. As I said in the tutorial, it's mostly a tapping process. You'll readily pick up how deep to make your lines or cuts or taps - - - . Shaping the edge is pretty easy, also. You'll pick up pretty quickly when that sharp edge you put on it starts getting dull - grooves get thicker. I have actually rounded the edge one time when I wanted a wide grooving than usual. It's pretty versatile. Just don't be too quick throwing away small ones as they wear down. When you get to shaping concave surfaces that need the Wonder wheel - those little ones can get in some tight places. There are places where I fall back on my Dremel tips, like around toes, or fingers and such. planeur and amazingkevin 1 1 Quote
planeur Posted February 17, 2020 Report Posted February 17, 2020 6 hours ago, Bpardue said: I bought the wonder wheel when I 1st started and did not care for it. I have better control by using my power carver and a cutoff wheel that way I can see what I'm doing. it is just easier for me Brian do you think those cutoff wheel could be small enought to fit on a 1/8" shaft of a Dremmel , like those ? In fact I just saw that your power carver look like my Dremmel. I am still looking for larger wheel....at least 2 " in dia. Thanks planeur Quote
amazingkevin Posted February 18, 2020 Report Posted February 18, 2020 This is news to me thanks for the tips an tricks!!! Quote
Frank Pellow Posted February 18, 2020 Report Posted February 18, 2020 I used one with moderate success to Judy Gale Robert's Beginner course. And I purchased a Wonder Wheel before I left. But, so far, I am more comfortable using a Dremel with carving tip. I do hope to get better with the Wonder Wheel but I do find it aggressive and a little scarry. Quote
Bpardue Posted February 21, 2020 Report Posted February 21, 2020 On 2/17/2020 at 4:10 PM, planeur said: Brian do you think those cutoff wheel could be small enought to fit on a 1/8" shaft of a Dremmel , like those ? In fact I just saw that your power carver look like my Dremmel. I am still looking for larger wheel....at least 2 " in dia. Thanks planeur yes they should Quote
