Awesome.  I have always loved this set of gnomes in fact I bought some intarsia ones already made for my daughter a couple of years ago but I love the color of yours they are so bright.  Extremely well done.  Like the laser printed signature on the back too.  Wish I could afford a desk laser engraver.
Marg
Marg
Thanks Marq , being a tool and technology junkie, I do spontaneous buys, this was one of them.  It is a great little machine. not terribly priced but there are several versions of this design out there. The one I bought uses a proprietary control software works very well but does not accept standard control codes(Gcode). Had I known that I would have bought a different brand. For most users that is a non issue. The company is coming out with a different control board and updated software.
I know, more information than anyone wanted.
Edited by Rolf
  • 6 months later...
NEJE did come out with a new control board which I bought and installed. I can now use other control software besides the one that came with the machine. I am currently using Lightburn. It has a 30 day free trial, if you like it is $40 and worth every penny.  As with all things there is a learning curve. I also just added a rotary jig so that I can engrave pens etc.
On 11/5/2020 at 11:39 AM, Fedido said:
Excellent job. always leaves me scratching my head on how these are done.
Fedido, These would be  more challenging if I did them in intarsia as each piece would have its own species of wood and grain direction. That means I would have to cut each piece precisely so that they all will fit together.
With segmentation I just use one piece of wood, put the pattern on, then with the smallest blade that will work (minimum kerf) in this case I used a Pegas MGT 1R, Then you just cut out the pieces like you would a puzzle.  If you decide to cut more than one Make sure to keep the parts together, don't mix them.
Use whatever tools you have to shape the pieces to suite your taste. Add any details, like the beard  etc. Paint ,stain or dye the pieces and carefully glue them together on a flat surface. I have a couple of granite slabs for my work surfaces. A really smooth flat  porcelain tile also works great. Or even a piece of glass. It is real easy to scape the glue off after you are done.
When the glue is dry I sand the back flat, then glue the assembly to a very thin backer (1/32 ply) to hide the seams on the back and strength.
The first one takes a bit of time, but if you are happy with it you use that one as an example, the rest go quick.
Edited by Rolf
That makes a lot of sense! Thank you for breaking this down to third grade level for me to understand. I have some Flying Dutchman 1 Ultra Reverse and I can’t even tell which side is up with them. Thank you again.
On the UR#1 blades, there is a little crimp in the top 1/2" of the blade. All FD UR blades are so marked. Should be apparent visually, but definitely you will feel it.
You are definitely schooling me. I thought I saw that before, but I don’t trust my eyes. I will look closer next time I start cutting.
Fedido, that is what forums like this are all about! We were all newbies at one point. I was lucky and have a local scrolling club that helped me tremendously, as forums were not that available back then. (2004)
  • 2 weeks later...
Very cool! I would have never guessed they were segmentation, as they look so much like just a carving. Excellent colors. I'm heading over to Bruce's site to check them out. Thanks for sharing.
