I'm looking for a new led magnifying  light.
I've had some in the past that made me dizzy.
Can someone recommend a GOOD quality LED magnifying light for scrolling?
A floor model would be ideal but could also use a clamp on model.
Thanks
I think you'll get more views and replies if you post your query in the General Scroll Sawing category. I wish I could remember what magnifier I have. Someone on this forum recommended it and I like it pretty well but it's not great. Trouble is we are all so different in our needs that what works great for one person may be mediocre to the next scroller. I went back and checked my order and here's the Amazon link
https://www.amazon.com/dp/B075ZYZP9J?psc=1&ref=ppx_pop_dt_b_product_details
Edited by oldhudson
43 minutes ago, rjweb said:
Some of the guys are using one from Judy gale Roberts, RJ
6 minutes ago, jerry1939 said:
I quit sawing a while ago.  Had a lighted magnifier.  DO NOT MOUNT IT ON THE SAW STAND.  Had to move mine because of the slight vibration from the saw.
jerry
I have the one from Judy. They are not cheap, but works well. I had gotten a cheaper one and it did not work as well, had a lot of distortion with it that I do not have with the one from Judy. I do have mine mounted to my saw stands and have not had any issue from vibration. I have been using them this way for more than 4 years. The one from Judy has two different lenses you can swap between depending on the strength you need.
https://intarsia.com/products/new-led-daylight-slimline-magnifying-lamp
I agree this would receive more attention in "General Scrolling" but since it is here I'll weigh in. I have the exact lamp you have on my 14" Hegner and I have found it to be nearly perfect. I have four mag lights. One fluorescent and three LED. Two are 5X which is way too strong for most people, one is 1.75X  on my 18" Hegner which is OK but the one you are using and mine are 3X. That seems to be an optimum for many scrollers. I like the idea that there is no distracting big ring around the lens. I have used those types for many years although not for scrolling as I have only been scrolling for about three years. I also like the streamlined look of it. There is only one disadvantage that I can see. Because the lens is so light weight the lamp sometimes tends to lift on its own a problem I fixed although I should not have had to do that. They must be popular because I believe I paid about $30 for mine and now I see they are over $60. To keep it from lifting I glued a couple of weights on the arm behind the lens and now it works perfectly. It is not mounted on the saw but rather on the adjacent bench. I love the light.
