Hello all, so I had someone request an ornament that looks like a "country crock" butter tub. Apparently their daughter loves butter so much that they keep an industrial sized tub on hand at all times. I thought she was joking. Apparently not. Anyone want to take a crack at making this resemble an ornament??
Maybe do a "REVERSE IMAGE" and do an image transfer
I have done many of these reverse image transfers and they look great
and they look painted on.
Print the label Reverse image, and get a bottle of Mod Podge:
Instructions
  1. Paint an even layer of Mod Podge across the entire wood surface. (add some to the image transfer also)
  2. Place the printed photo face down onto the wood.
  3. Allow wood piece to dry for 72 hours. (72 Hrs is a suggestion but do make sure it has dried.)
Spray the back of the photo with water or dampen it with a sponge. (remove gently and add more water as you go)
  1. Gently start rubbing the wet paper. ...
You will begin to see the photo showing through
It will take a little practice and will look professionally done with a couple coats of lacquer.
Edited by LarryEA
Instructions
One thing I left out:
  3. One thing I left out: Roll all the excess Mod Podge out ASAP
  4. Allow wood piece to dry for 72 hours. (72 Hrs is a suggestion but do make sure it has dried.)
  5. I remove the paper with a wet finger, very gently
Edited by LarryEA
Instructions
The only issue with this would be the printing would also be reversed,  therefore, challenging to read!
My instructions noted to print a "REVERSE IMAGE" and then do an image transfer.
See above do a "REVERSE IMAGE" and do an image transfer
