Popular Post FrankEV Posted February 13 Popular Post Report Posted February 13 (edited) I adapted a free image of a metal wall hanging to create a nom 10 ½” x 14” Intarsia pattern. Wood used: Aspen, Basswood, Poplar (textured with a wire wheel and enhanced with Green Acrylic paint applied with an Air Brush), Padauk, Walnut, Wenge, Yellowheart, and a Tan mystery wood for the island. The backer is a nominal 5/8” thick Premium Pine panel that was lightly painted using an Air Brush to create a sea to sky background while allowing some of the strong Pine grain to show through. The rails of the Walnut fixed frame are 1 ½” wide forming a 15” x 19” panel. Finish is rattle can spray Clear Gloss Acrylic Finish. Comments and critiques are always welcome. EDIT 2: Yep the sun WAS in the water!!!!! Did not see it until I looked at the original photo with this post. The glue had not curred fully and I was able to remove the sun completely without much visable damage to the background. I'll be deleting the sun from the pattern. With my interpretation of the Island, I feel it is no longer needed. Kind of looked wrong even without the colored background. Edited February 14 by FrankEV Scrappile, ChelCass, Gonzo and 7 others 9 1 Quote
preprius Posted February 13 Report Posted February 13 Frank This is much better than a piece of metal. Everything looks well blended with both grain and colors. The 1 thing is the sun position. It just does not look right. In my mind it seems below the water level. FrankEV 1 Quote
FrankEV Posted February 13 Author Report Posted February 13 (edited) 17 hours ago, preprius said: Frank This is much better than a piece of metal. Everything looks well blended with both grain and colors. The 1 thing is the sun position. It just does not look right. In my mind it seems below the water level. You are 100% correct. I'm contemplating how to fix. My adding the coloration to the backer caused the problem. I did not see the problem until I took the pic and submitted this post. Sometimes you don't see a mistake until it is too late. I may attempt to remove the sun. it is too late to change the coloring of the background. EDIT: See revised Post Edited February 14 by FrankEV Quote
preprius Posted February 14 Report Posted February 14 With the pattern starting as a metal art piece, the sun had to connect to something. So we should be careful of patterns from other media. FrankEV 1 Quote
FrankEV Posted February 14 Author Report Posted February 14 (edited) 10 hours ago, preprius said: With the pattern starting as a metal art piece, the sun had to connect to something. So we should be careful of patterns from other media. Yes but it was my background coloring that put the sun underwater. EDIT: See revised Post Edited February 14 by FrankEV Quote
barb.j.enders Posted February 14 Report Posted February 14 Nice work Frank. Could you adjust the colouring around the sun. Make it look more like a setting sun. FrankEV, Roberta Moreton and ChelCass 2 1 Quote
TAIrving Posted February 14 Report Posted February 14 The picture does not show up for me. When I click on the link, I get a tiny unrecognizable something. Quote
FrankEV Posted February 14 Author Report Posted February 14 (edited) 35 minutes ago, barb.j.enders said: Nice work Frank. Could you adjust the colouring around the sun. Make it look more like a setting sun. Not that easy with the assembly glued in place. Air brush work is dificult to repair in this kind of situation. See revised Post. I think it looks better. Edited February 14 by FrankEV barb.j.enders 1 Quote
FrankEV Posted February 14 Author Report Posted February 14 4 minutes ago, TAIrving said: The picture does not show up for me. When I click on the link, I get a tiny unrecognizable something. Try again. I was editing! Quote
Scrappile Posted February 14 Report Posted February 14 Very well done Frank. The kind of picture I can look at and think smooth, relaxing thoughts! barb.j.enders and FrankEV 1 1 Quote
rjweb Posted February 14 Report Posted February 14 Frank, it looks better to me without the sun, RJ FrankEV 1 Quote
barb.j.enders Posted February 15 Report Posted February 15 23 hours ago, FrankEV said: Not that easy with the assembly glued in place. Air brush work is dificult to repair in this kind of situation. See revised Post. I think it looks better. I noticed that change on the FB group. Looks good. FrankEV 1 Quote
TAIrving Posted February 15 Report Posted February 15 On 2/14/2025 at 8:14 AM, FrankEV said: Try again. I was editing! Thanks Frank. That looks very good! FrankEV 1 Quote
wombatie Posted February 18 Report Posted February 18 Love the look of the palm trees. Excellent work Frank. Marg FrankEV 1 Quote
Dan Posted February 18 Report Posted February 18 On 2/13/2025 at 2:22 PM, FrankEV said: EDIT 2: Yep the sun WAS in the water!!!!! Did not see it until I looked at the original photo with this post. Oh,I thought it was a sunfish. FrankEV and barb.j.enders 2 Quote
