Popular Post don in brooklin on Posted August 11, 2025 Popular Post Posted August 11, 2025 My wife liked the butterflies that I created for the fence so I thought I would make a sign for the gate to out backyard. TIP: It is the same design as before except smaller. When I did the yellow in the wings before I cut out at 7 degrees so they would drop about 1/16 on an inch. This time I cut at 90 degrees with a 2/0 blade as they would have a backer to glue to. I then sanded off 1/16 or so on the drum sander. The pieces were quite small and so when I paint with the rattle can I was worried that they would blow over so I put a 2 inch piece of painters tape on a piece of wood. I put on some dabs of CA and other piece so the sticky side up and attached the small pieces. Works quite well. See pic below. wombatie, red river, Archer and 8 others 11 Quote
scrollerpete Posted August 11, 2025 Posted August 11, 2025 You are collecting “ BROWNY” points, very nice Quote
rjweb Posted August 11, 2025 Posted August 11, 2025 don, another excellent job for the yard, RJ Quote
heppnerguy Posted August 11, 2025 Posted August 11, 2025 8 hours ago, don in brooklin on said: My wife liked the butterflies that I created for the fence so I thought I would make a sign for the gate to out backyard. TIP: It is the same design as before except smaller. When I did the yellow in the wings before I cut out at 7 degrees so they would drop about 1/16 on an inch. This time I cut at 90 degrees with a 2/0 blade as they would have a backer to glue to. I then sanded off 1/16 or so on the drum sander. The pieces were quite small and so when I paint with the rattle can I was worried that they would blow over so I put a 2 inch piece of painters tape on a piece of wood. I put on some dabs of CA and other piece so the sticky side up and attached the small pieces. Works quite well. See pic below. I am trying to learn how to use my air brush and had a lot of problems with the pieces taking off when I sprayed them. I used double sided tape the next time but I like your way better. Thanks for the tip. I like your use of the colors to offset the different parts. It looks great Dick heppnerguy Quote
