My wonderful brother-in-law has a fantastic model railroad outside his home in the White Mountains of Arizona. He asked me to make a garden arbor for his layout. Given how generous he's been to me I agreed immediately. I've never done a project like this before, lots of challenges.
The wood is cedar, I'm guessing but don't know for sure, that it's ERC. I picked the straightest grain stock from my pile for this. I sliced off a couple of sections from a 4" x 4" about 20" long into stock about 3 1/2 x 3/8" x 20" thick with the bandsaw. They were so thin I used double sided tape to attach them to a carrier board to run through my planer - one to 1/8" thick and the other to 1/4". Sorry no pics.
Then I ripped the stock on the table saw to 1/8, 1/4, and 1/2 as needed. post-18045-0-88431300-1460315964_thumb.jpg
For cross cutting (some pieces were as short as 1 1/2") I made a new cross cut sled for these little parts.post-18045-0-70673800-1460316050_thumb.jpg
I had to cut a notch, like one half of a half lap joint to attach the rafters to the lentils. I attached a stop to the miter gauge and added a small piece 1/8 x  1/4 x 1 1/2 to cut the notches. Just like making finger joints really. post-18045-0-76707800-1460317258_thumb.jpg
I used TB III for the glue-up and applied it with a paint brush. I used a framing square to line up parts for the assembly and used weight for clamping pressure. post-18045-0-70864000-1460316416_thumb.jpgpost-18045-0-52745300-1460316437_thumb.jpg
I applied McCloskies spar varnish, once again with a paint brush. I probably should have done the finishing before assembly but...?  The first coat was right out of the can. The second coat I cut with paint thinner - it went much better. I learn by making mistakes. The final pics are with 2 coats. post-18045-0-87379500-1460316849_thumb.jpg
I still have to figure out what to attach the unit too so I doesn't blow away. I'm thinking to attaching it to a piece if stone tile with construction adhesive.
Thanks for looking.
Edited by oldhudson
The wood is cedar, I'm guessing but don't know for sure, that it's ERC. I picked the straightest grain stock from my pile for this. I sliced off a couple of sections from a 4" x 4" about 20" long into stock about 3 1/2 x 3/8" x 20" thick. They were so thin I used double sided tape to attach them to a carrier board to run through my planer - one to 1/8" thick and the other to 1/4". Sorry no pics.
Then I ripped the stock on the table saw to 1/8, 1/4, and 1/2 as needed. attachicon.gifMGA 524.jpg
For cross cutting (some pieces were as short as 1 1/2") I made a new cross cut sled for these little parts.attachicon.gifMGA 521.jpg
I had to cut a notch, like one half of a half lap joint to attach the rafters to the lentils. I attached a stop to the miter gauge and added a small piece 1/8 x  1/4 x 1 1/2 to cut the notches. Just like making finger joints really. attachicon.gifMGA 540.jpg
I used TB III for the glue-up and applied it with a paint brush. I used a framing square to line up parts for the assembly and used weight for clamping pressure. attachicon.gifMGA 542.jpgattachicon.gifMGA 543.jpg
I applied McCloskies spar varnish, once again with a paint brush. I probably should have done the finishing before assembly but...?  The first coat was right out of the can. The second coat I cut with paint thinner - it went much better. I learn by making mistakes. The final pics are with 2 coats. attachicon.gifMGA 549.jpg
Thanks for looking.
He will be pleased for sure!Nice clean job,you now how to have fun !thanks for showing!
Great looking piece.  Been thinking model railroading is a market perfect for scrollers. We are used to working with small tolerances on small pieces.
I think there may be a market there. I don't think there is any doubt that those involved in model railroading spend serious dollars on their hobby (so do many woodworkers). Some may be DIY'ers but I'm sure a portion aren't. You'd have to see what's available and find items that aren't represented or poorly done. Then figure out how you'd reach your audience.
