Because I wish to eventually get to portrait patterns I thought I would take a crack at one.. So I tried two different versions on the same pattern. Which one do you like better ?  Then can anyone tell who this is supposed to be? I guess that is the true test of things. I understand that there are a variety of ways to make a pattern and I would like to try a least a couple of them. So here is my first effort,  so that I can get some opinions on them. Please honest, should you choose to chime in and help me.. Which one do you judge to be the better or do both of these suck. You won't hurt my feelings so fire away, I am looking for both positive and negative statements as that is what is going to help my in the long run..
Dick
heppnerguy
While I made my choice before scrolling and seeing everyone else's reply - I also chose #2 - the one on the right - so so far you have 11 votes and all for #2.  I agree, the reason I liked #2 better was the smaller "Shadow" on his left side of his face.  While I thought both looked like Dr MLK, I thought #2 was a little better likeness overall.  As you say, in some part - the "art" in making the pattern is by the pattern maker and the choices they make "artistically" to get across the image they have in their mind.  I think you are doing great work in learning to make your patterns.  Keep up the good work.
I too like the same as the rest. I see a lot of pieces that have heavy shadow on them like the first one here and thought I would try to see if I could figure out how it is done.. Obviously, I have  not nailed it yet but I will continue to try to understand how this is accomplished.. How can I learn if I do not..Thank you everyone for your input
Dick
heppnerguy
