Sanding mop grit
Go to solution Solved by tgiro,
I have the sanding mops from Klingspor and when I use them I use a 220 the most, I guess (I have 120, 220 and 320 grits).  I seldom use them anymore because I purchased the Mac Mops and for my purposes I like them better.  Of those I use 180 grit the most.  I finishes about like 220 grit sand paper..
1 hour ago, octoolguy said:
Geez people, I'm still trying to get over the cost of buying one and you all have multiples?
Don't feel too bad Ray... I've been going to buy just one of them someday now for about 12 years.. I still don't have one.. I did however run across one f these while shopping at Harbor Freight... Probably not as good as the sanding mop... but man I sure do like it and use it much more than I ever thought I would.. I bought another one for a spare the next time I stopped in there.. but have yet to wear the first one out.. Been about 8 months on just the one....I also noticed that it has a screw that comes out of the arbor that holds those scotchbrite pads on... I don't know if it's cost effective to buy just the pads and replace them or just buy a whole new one. since they don't really cost all that much... Now I just need a dedicated rill press for it.. actually like to get two drill presses.. one for my forstner bit for drilling the clock holes.. and one for my sanding..of coarse the one for drilling the pilot holes for my fretwork, LOL
https://www.harborfreight.com/4-in-180-grit-abrasive-ball-61184.html
Edited by kmmcrafts
Thanks Kevin, I do recall seeing those when over there last but wasn't sure they would do what I needed. Now, I guess I'll have to invest in one.
  • 2 weeks later...
  • 5 weeks later...
On 10/1/2018 at 9:38 PM, ike said:
I made one and used 150 grit . It is what I have platy of I have a 6" roll. It works fine.
IKE
Hi Ike, you made one I was thinking of doing this as well. I have some ideas how to go about it, but how did you make yours. I have gone to every store around here and no one has even heard of a sanding mop.
Irene
Got to sanding  mop  on you tube and find instructions there. That would be a lot easier than me explaining it I made mine a 6' mop. I drill press  it on slow speed on my drill press. It takes about an hour to make and a lot of emery paper  If you can't find it on You tube let me know and I will try and find it.
IKE
  • 2 weeks later...
  • 2 weeks later...
On 11/14/2018 at 9:57 PM, amazingkevin said:
I've made a lot of them with a bolt, washers and a nut. I couldn't find my go to one and could only find the 5/8" wide 80 grit one. I had fragile fretwork to try it one and was amazed it did no harm at all to it.
Kevin, what diameter did you make. I'm thinking of making one but I'm not sure as to just how big. I bought a mandrel at H/F. I bought a roll of emery cloth on Amazon that is about 1 1/2" wide in 180 grit. What do you think?
