planeur Posted November 14, 2019 Report Posted November 14, 2019 When doing intarsia, I am looking for a glue which would be enough strong to hold pieces together, but also be able to separate those 2 pieces easily. What do you think of putting a small amount of hot glue with a hot glue gun ? I want to put together all the pieces to see if everythink is OK , before the final gluing to the back ? Merci ! planeur Quote
spirithorse Posted November 15, 2019 Report Posted November 15, 2019 Hi, Planeur, I did read somewhere that Judy Gale Roberts has suggested that using small dots of hot glue can help keep everything aligned while putting the pieces together. My approach to that is just using wood glue and assembling all the pieces on wax paper. The pieces can be slid on the wet glue, on the wax paper for a long time before the glue sets up so you have plenty of time to assemble the whole project. Then, you can either carefully slide the whole project onto your backer board or, what I prefer to do is, allow that to dry until the glue is cured. Then, remove the wax paper from the back of the completely dried project, put it on your backer board to trace around the edges for a perfect fitting backer, and then apply glue to the backer and clamp the project onto the backer board. Since many intarsia projects have several layers or thicknesses, you may just want to place weight on top of the project to make sure it lays flat on the backer board until the glue is completely cured. I hope this is of some help. God Bless! Spirithorse Whisper, Steve Curtis and planeur 2 1 Quote
amazingkevin Posted November 15, 2019 Report Posted November 15, 2019 Vinegar will dissolve Elmer's glue. JimErn, planeur and LarryEA 3 Quote
JimErn Posted November 15, 2019 Report Posted November 15, 2019 9 hours ago, amazingkevin said: Vinegar will dissolve Elmer's glue. Thanks, that is good to know amazingkevin 1 Quote
planeur Posted November 15, 2019 Author Report Posted November 15, 2019 Merci Bob and Kevin ! I will try first the hot glue spot. 10 hours ago, amazingkevin said: Vinegar will dissolve Elmer's glue. Even when the glue is dry and set up ? What is the effect of the vinegar on wood , could it change the color of the wood a bit or nothing ? Have a good day ! planeur Quote
meflick Posted November 15, 2019 Report Posted November 15, 2019 You can also use double sided tape (carpet tape is what Judy uses in her classes) to temporarily hold things together. planeur and Ivan Nikolaev 1 1 Quote
planeur Posted November 15, 2019 Author Report Posted November 15, 2019 Merci Mélanie I will also use this option , and probably is very good et easily reversible! planeur amazingkevin 1 Quote
meflick Posted November 15, 2019 Report Posted November 15, 2019 2 hours ago, planeur said: Merci Mélanie I will also use this option , and probably is very good et easily reversible! planeur You're welcome. Get a moderate holding tape not the really "firm" tape and don't use a lot, just a little will go a long way usually. Quote
Phantom Scroller Posted November 15, 2019 Report Posted November 15, 2019 (edited) I use hobbycraft repositionable spray adhesive all the time to stick my patterns to the wood then put two inch sellotape on top and have never had any issues with it coming off until I pull it off. Roly oops misunderstood I would use masking tape on both pieces of wood and superglue between the masking tape. Edited November 15, 2019 by Phantom Scroller planeur 1 Quote
amazingkevin Posted November 15, 2019 Report Posted November 15, 2019 9 hours ago, planeur said: Merci Bob and Kevin ! I will try first the hot glue spot. Even when the glue is dry and set up ? What is the effect of the vinegar on wood , could it change the color of the wood a bit or nothing ? Have a good day ! planeur I,ve not noticed any change and yes wet or dry it breaks the bond to the eood planeur 1 Quote
Dave Monk Posted November 25, 2019 Report Posted November 25, 2019 On 11/15/2019 at 8:30 AM, meflick said: You can also use double sided tape (carpet tape is what Judy uses in her classes) to temporarily hold things together. Melanie, Excuse my ignorance, do you put the tape between the pieces or under? Quote
tgiro Posted November 25, 2019 Report Posted November 25, 2019 35 minutes ago, Dave Monk said: Melanie, Excuse my ignorance, do you put the tape between the pieces or under? On the back of the pieces, usually to a sanding shim or back board. The common practice is to hold a number of small pieces together to make a lager piece so they can all be sanded at the same time. When I glue pieces together for fit or any other reason, I use Kathy Wise's trick - one small drop of super glue on one piece and spray accelerator on the other. Then hold them together. Put the drop of glue close to the backside of each piece. That way, if it does chip the wood when you break them apart, the ship is where you won't see it. The accelerator, as well as speeding up the drying time of the glue, makes the glue somewhat brittle and easy to break apart. Dave Monk and planeur 1 1 Quote
jollyred Posted November 25, 2019 Report Posted November 25, 2019 I usually use blue painter's tape to hold the pieces together, with a nonslip pad underneath to keep it from sliding around. When it is time to glue it up, I slide the whole thing onto the backer, then remove the tape from a few pieces at a time till they are all in place. I will usually only do about 10 minutes of gluing at a time before applying weight to help the glue hold. Tom planeur and Dave Monk 2 Quote
Rolf Posted November 26, 2019 Report Posted November 26, 2019 if you are doing an assembly for shaping purposes then I put small pieces of double sided carpet tape on a masonite backer. Or if it is just a couple of pieces I sue a drop or two of thick CA. It is brittle and will break apart fairly easily. Do test first on scraps so you know what to expect. For dry assembly test of the project, I take a piece of clear removable shelf paper and tape it sticky side up on a flat surface, for me that is a piece of granite slab. You can then place the pieces without them moving around. Dave Monk and planeur 1 1 Quote
Frank Pellow Posted December 1, 2019 Report Posted December 1, 2019 I'm a little late in responding to this bit I, too, use inexpensive double sided tape for attaching intarsia pieces temporarily. planeur 1 Quote
planeur Posted December 2, 2019 Author Report Posted December 2, 2019 (edited) Thanks everyone, until today , I have used hot glue and kind of cyanocrylate glue , depending the space of the joint! I have used double side tape when I was finished rounding pieces and installed them together. Will show you soon.... planeur Edited December 2, 2019 by planeur Quote
Whisper Posted January 16, 2020 Report Posted January 16, 2020 On 11/14/2019 at 9:05 PM, amazingkevin said: Vinegar will dissolve Elmer's glue. Awesome tip. There isn't much vinegar can't do. Quote
Jim Finn Posted January 20, 2020 Report Posted January 20, 2020 On 11/14/2019 at 9:05 PM, amazingkevin said: Vinegar will dissolve Elmer's glue. As will water. Quote
teachnlearn Posted January 21, 2020 Report Posted January 21, 2020 (edited) I used 'glue dots' for business pamphlets. Stuck the business card to the pamphlets. There are various tack levels, from low tack to permanent. Check before you buy. There are enough in a pack to last through quiet a few pieces. I get them by the roll of 4000, but hand out 100ths a day. RJF https://www.amazon.com/s?k=low+tack+glue+dots&ref=nb_sb_noss Double check the 'tack' before buying or you maybe permanently gluing your project. https://www.amazon.com/Glue-Dots-Dispenser-Applicators-4000-count/dp/B07D6NFNSX/ref=sr_1_7?keywords=low+tack+glue+dots&qid=1579630650&sr=8-7 Edited January 21, 2020 by teachnlearn Quote
