6 minutes ago, JTTHECLOCKMAN said:
If you routed that all in using a router, that is impressive. That is a steady hand for sure. That has to be done all freehand. I have never attempted something that involved but have done a few designs and my hands are not what they use to be. Nicely done.
Why thank you John.  Yes I used a router with a CNC bit.  It tried my patience that's for sure.  I printed the pattern, traced it onto the wood, held my breath and !!!  It's only my second piece using the router, but it's good fun and very 'different'  🤣
Just had a thought. !!  For all you lovely people that have left such flattering comments, I should confess that I don't use my router with the big heavy base that most people use. My hands would not cope with pulling that around. So I swapped the 'big' base for a little 'baby' base.  It makes things so much easier for me, so I think I'm not so much 'talented' as a big Wuss  🤣
Edited by Foxfold
Again still impressive and the reason is both hand eye coordination still is a factor because it is freehand and many times grain of the wood will pull the small router bits off the line.
I use 2 types. The first is by Stew Mac and is used with a dremel. These are great because the dremel can be pushed and pulled with little effort because so light weight. Yes it is a professional plunge system but they do sell a cheap version that I have used on occassion too that is made for dremel.
Then there is my more expensive version that uses my colt Bosch router something like what you have. Now this is so dead on accurate I can cut the thickness of a sheet of paper and thinner if need be. Have a light on it and it is expensive. But have used this to do inlays.
https://www.stewmac.com/Luthier_Tools/Tools_by_Job/Tools_for_Inlay_and_Pearl_Cutting/Precision_Router_Base/Precision_Router_Base.html
https://microfence.com/product-category/plunge-bases/
I totally agree with the above posts!!!  I also have the Stew Mac base for my dremel,  it is a great tool, I used it a lot when I was into making cigar box guitars.  But it does not "plunge".  It is easily "plunged" by leaning it back and moving it upright where you want to start routing.  I will probably use it more as I make more boxes and clocks...
Brenda, I have a CNC machine and trust me when I say, you are one talented freehand artist!  The router is a wonderful if not ornery tool.  The bit is rotating in a specific direction and not always in agreement with the grain of the subject piece.  To do as wonderful a job on a hunk of wood, freehand, is extraordinary to say the least!  👍 👍  Well done and I am a fan!  Russ
11 hours ago, JTTHECLOCKMAN said:
It is the lettering that stands out the most. Many times like with scrolling you can fudge mistakes and hide them as if they were part of the pattern. But lettering with a distinct style needs to be dead on and this is. Again A+++
Exactly.  I don't think I could do as good of a job if I free handed that pattern with a pencil.  😄
Right there with you and this is coming from someone who has tried doing inlay work and routing of this nature. Enough can not be said. Impressive.
There is always some works here such as Dave Monk's inlayed boxes and things like this that just jump out at you and you know that person has talent. I never tire of looking at things like this.
Edited by JTTHECLOCKMAN
16 minutes ago, amazingkevin said:
I had to see this close-up and the smoothness of the cuts is immaculately perfect. I wonder what kind of wood it is? I'll bet it's soft for you to have such control. !!! Good job!!!!
It is Kevin.  It was an industrial piece of plywood about ½ inch thick. Decided to use it as a 'test' piece to see if I could cut something that big before I tried it on 'proper' wood. LOL.    Tony liked it that much it's still here !!
  • 3 weeks later...
