Hey Carl, I would rather the pattern stay stuck to the wood rather than it coming loose while I’m cutting. Some folks use blue painters tape under the pattern. The tape makes it easier to peel off the pattern, however, I don’t like using blue tape because I hate dealing with the little pieces of tape left behind. I use 3M Super 77 spray adhesive. I spray a light coat on the back of the pattern, let set for about 30 Seconds then apply to the wood. After cutting, the pattern easily comes off with the help of a heat gun or hair drier. Apply heat to the pattern and it loosens enough to peel the pattern off. Or you can spritz some mineral spirits on the pattern. This will loosen the pattern from the wood. Then just peel it off.
Hi Carl,I use Elmer spray glue,get it ad Wal-Mart or most hardware stores.Lots of the folks in here use super 77.I have
great luck with elmer,so I stick with it.Secret with these spray glue is to use a light spray on the pattern.Don't  drown it lol.
I find also to always shake can well and stay back from pattern a bit so not to get drips falling on pattern.I also don't use tape any more.
Usually pattern lifts right off,but if not I give it a dab of mineral spirits..hope this is of some help..Gordie
Tried the tape, I don't like the cut track.  Does mineral spirits do anything to the wood that affects finishing?  I will try the heat and different glue.  Thanks all.
Does everyone use just regular printer paper?  Seems all my problems are the paper separating.
Yes, just cheap printer paper. Mineral spirits will dry very quickly. If using an oil based finish, mineral spirits will have no effect on the finish. If using a water based finish, just let the mineral spirits dry for 24 hours. You can use shellac right away. But in any case, about time you do your final sanding you are good to go.
Edited by dgman
On 4/10/2020 at 4:40 PM, Bucky 80 said:
Is there a favorite repositional spray glue brand for attaching patterns to wood?  Last couple of projects, getting the pattern off the wood was as tough as cutting out the pattern.
You can use a spritz of mineral spirits or a heat gun. I prefer the heat gun. 3m 45 is my preference for glue.
On 4/12/2020 at 6:48 PM, LarryEA said:
I'll throw in my option. For most of how I attach my patterns is using
 Glad Press n Seal Food Wrap.
First I cover the wood with Press n Seal then spray glue the pattern
and attach it to the Press n Seal.  Can reposition if necessary.
The Press n Seal is see through
Larry, I have never heard of that. Thanks for sharing.
Dave I will go into a little more detail.  It is GLAD'S Press n Seal
It is best used on patterns (wood,etc) that is 6" or bigger.
I have a small roller that I use to smoothe.
I read the title again and realized this does not help for repositioning patterns.
I suggest expermenting a couple times. Press n Seal is all I use.
Larry, Do you have to sand and clean the wood good before you put the Press n Seal on?
Dave,   You do not need to do anything.  It sticks  and peals off even after days.
But why would you not sand and clean first
  • 2 weeks later...
i used to use only spray adhesive on my patterns. did not like having to put mineral spirits on to take pattern off. saw iggy using shelf liner on here and tried it and it works great. peels right off after im done cutting and no residue is left on the wood. for glue i use loc tite brand spray adhesive from lowes. low cost and goes a long way. so does the shelf liner which i got at walmart.
doug
I use the cheapo spray glue from walmart or wherever I can get it.
There is a bit of an art to it.
1- spray the paper with a very. very light coat of glue, very light, should not be shiny.
2- wait at least 20- 30 minutes.  It should be just barely tacky and by barely I mean way less tacky than a post it note. It it is post it note tacky, it will never come off the wood. if it is too tacky, wait another 5-10 minutes. barely tacky.  like you can touch it and wonder if glue is actually on it tacky.
3- apply to the wood.
