I cut this dragon this morning, and as someone had said so eloquently, it was a constant "breath hold" moment LOL
Anyway, now that it's cut I'm scared to sand the thing LOL
So, I'm looking for suggestions on how best to sand this without breaking the thing. I'm not considering using any of the machine sanders at the moment
The whole dragon measures 10" W x 1 3/4" H at it's widest point (just behind front claw)
Thanks as always in advance for reading
Edited by new2woodwrk
I might try using "Handy Tak", the temporary putty like adheasive use for posters, etc., to temporarily affix it to a board whilse sanding.     This stuff holds fairly well and removes easiy.  If it seems to be holding too well, it can be cut off easily with dental floss.
I guess you plan on hand sanding, but if secured as above, a sanding mop used very gently should also  work nicely.
I love the beautiful scroll work.   Great job, but can undersatnd the "breathy hold" moments.
Would love to hear how you plan on finishing and mounting it.    Of course, as allways, post a photo when it is completely finished.
Edited by FrankEV
I've got a piece of Corian that was the sink cutout for our kitchen sink. I tape a couple of sheets of paper to it and "CAREFULLY" sand most everything that has a flat area. For the intricate areas, an old worn Macmop at a slow speed would work. Just be careful with it. I used a 220 Macmop on this thing and it worked great.
35 minutes ago, Paladin said:
for all puzzles like that I use a mop sander.  Looks like it's cut out of at least 3/4" material?  It is stronger than you think if you use the mop sander gently.
What he said, and sand it one piece at a time
This is one piece and not a puzzle...correct?  A lot of replies seemed to think it was multiple pieces.
Your question is really how to hold it while sanding so it doesn't break at the weak points...Correct me if I'm wrong.
It is indeed a puzzle with 7 pieces.
The problem areas are the scales that stick out all around the body
Try sanding with an airbrush eraser.
