Frank Pellow Posted February 4, 2022 Report Posted February 4, 2022 (edited) I'm attaching a PDF file that describes a typical process that I use to make sure that my typical customer feels part of the project and likes the result. By the way, my customers don't pay me directly. Rather, I make things for them in return for them making an appropriate donation to 'Medicins Sans Frontieres' (Doctors Without Borders). If the cost of materials and postage is less than $100, I eat the cost. I ask to be reimbursed for any cost over $100. I also suggest a minimum amount that they should donate (but, do not follow up on this). I've been doing this for about 6 months and, so far, all my customers have come to me by word of mouth. Here is a photo of the sign that I made for my customer: Life's Better on Canna.pdf Edited February 7, 2022 by Frank Pellow cwright, ChelCass, meflick and 3 others 6 Quote
heppnerguy Posted February 4, 2022 Report Posted February 4, 2022 Thank you showing exactly all the steps you went through to come to your final results. It was well thought out and executed. I have never gone through a process like you just demonstrated and appreciated you taking the time to show the process you did and your thoughts on it as you eventually came to the decision your reached. I found it not only very informative but also quite interesting. Dick heppnerguy Quote
Frank Pellow Posted February 4, 2022 Author Report Posted February 4, 2022 (edited) 4 hours ago, heppnerguy said: Thank you showing exactly all the steps you went through to come to your final results. It was well thought out and executed. I have never gone through a process like you just demonstrated and appreciated you taking the time to show the process you did and your thoughts on it as you eventually came to the decision your reached. I found it not only very informative but also quite interesting. Dick heppnerguy Thanks Dick. I guess that the PDF attachment worked. Edited February 5, 2022 by Frank Pellow Quote
heppnerguy Posted February 5, 2022 Report Posted February 5, 2022 4 hours ago, Frank Pellow said: Thanks Dick. I guess that the PDF attachment worked. It did very well. Thanks again for posting it Quote
don watson Posted February 5, 2022 Report Posted February 5, 2022 Thanks for this Frank. I will check it out later. Don W Quote
Dan Posted February 5, 2022 Report Posted February 5, 2022 Cool story and good for you. Hope you get swamped with customers. Quote
preprius Posted February 5, 2022 Report Posted February 5, 2022 (edited) deleted.... sketch. Nice sign. Good coloring. And yes as the PDF file shows keeping the customer engaged is good. Edited February 5, 2022 by preprius miss understood the sign. Quote
Frank Pellow Posted February 5, 2022 Author Report Posted February 5, 2022 43 minutes ago, preprius said: I just want to make sure I understand what you trying to teach is....See cartoon sketch... Sorry for for bad drawing. I had to get it down on paper fast. I guess the main thing I am stressing is to keep your customer informed and involved. Make them feel that they own the project and this will make them proud and happy with the item produced by the project. Quote
preprius Posted February 5, 2022 Report Posted February 5, 2022 (edited) If I was wrong I will delete my sketch. Edited February 5, 2022 by preprius removed stupid comment. Quote
Frank Pellow Posted February 5, 2022 Author Report Posted February 5, 2022 (edited) 1 hour ago, preprius said: So I guees I missed what Canna is meaning. Canna is not Canada. So I jumped to the conclusion the sign was refering to Canabus plant. If I was wrong I will delete my sketch. Sorry, but you were wrong. But, it is an interesting cartoon. Canna is the name of an island in Georgian Bay (Lake Huron) and that has been the name of the island for a very long time. Edited February 5, 2022 by Frank Pellow Quote
Wichman Posted February 6, 2022 Report Posted February 6, 2022 I have a question for you; how do you support the piece as you are cutting the very ends of the boards? It looks like you angle the piece to keep as much of the board on the table as possible, is that correct? Quote
Frank Pellow Posted February 6, 2022 Author Report Posted February 6, 2022 (edited) 12 hours ago, Wichman said: I have a question for you; how do you support the piece as you are cutting the very ends of the boards? It looks like you angle the piece to keep as much of the board on the table as possible, is that correct? When cutting with a regular (that is, non spiral) blade near the end of a piece this long, sometimes you have no choice but to have most of the piece off the table. I usually sit to scroll but, with this piece, I had the stand a lot of the time. A few years ago, I made a temporary larger table table and, sometimes, I use that when cutting very large pieces. Here is a photo of that table: I did not need to use that table when cutting the Canna sign. I have a infeed/outfeed adjustable roller stand that is mostly for use with my tablesaw and bandsaw. Very rarely, I have also used the roller stand to support pieces that I am cutting with my scrollsaw. Edited February 6, 2022 by Frank Pellow Wichman 1 Quote
Roberta Moreton Posted February 7, 2022 Report Posted February 7, 2022 That was very informative! Frank Pellow 1 Quote
Millwab Posted February 12, 2022 Report Posted February 12, 2022 Frank, just curious. You chose white oak for its outside durability but you backed it with BB ply. Aren’t you afraid the ply will delaminate outside? Quote
Frank Pellow Posted February 12, 2022 Author Report Posted February 12, 2022 1 hour ago, Millwab said: Frank, just curious. You chose white oak for its outside durability but you backed it with BB ply. Aren’t you afraid the ply will delaminate outside? That was is a slight concern. There are a couple of things that I hope will help. First, being on the back, it's better protected. Second, I drove several screws in through the back of the sign. Of, course, I also used glue that is good outside and I sprayed he whole sign including the back with an exterior grade clear finish. Quote
