Wichman Posted December 13, 2025 Posted December 13, 2025 (edited) I came up with this scheme a couple of years ago, and it worked for smoothing the wood planks too wide for my 12 and 1/2" planer. I recently ( thanks to the HF manager who let me take apart the machine in the store and check to see if the larger diameter brush still had clearance, it does, yeah! ). I ordered a drum with abrasive nylon bristles, 320 grit, It doesn't remove all the fuzzies, but it does an excellent job of smoothing the shellac ( in preparation for more coats ). Note the hi tech "sandbag" for retaining the handle The " surface conditioning tool" is locked on, at 1000 rpm, and plugged into a foot switch. When not in use the tool switch is off and the foot switch is unplugged. Edited December 13, 2025 by Wichman Additional information BadBob, danny and Scrappile 3 Quote
Wichman Posted December 13, 2025 Author Posted December 13, 2025 57 minutes ago, Denny Knappen said: I still like my Sand Flee. To bad they don't make them anymore. Quote
barb.j.enders Posted December 14, 2025 Posted December 14, 2025 21 hours ago, Wichman said: To bad they don't make them anymore. Similar product. https://stockroomsupply.com/collections/flatmasters-and-diy-drum-sander-kits Wichman 1 Quote
Denny Knappen Posted December 15, 2025 Posted December 15, 2025 On 12/14/2025 at 9:18 AM, barb.j.enders said: Similar product. https://stockroomsupply.com/collections/flatmasters-and-diy-drum-sander-kits Thanks, Barb, for the information. If the Sand Flee dies, this will be a go to. barb.j.enders 1 Quote
