Popular Post Kris Martinson Posted April 26 Popular Post Posted April 26 I just finished cutting this. Lots of hours at the scroll saw. Pattern by me. Roberta Moreton, meflick, Dan and 17 others 18 2 Quote
rjweb Posted April 26 Posted April 26 Kris, your work is amazing excellent cutting and designs, RJ Kris Martinson 1 Quote
Mike Crosa Posted April 26 Posted April 26 Agree excellent cutting and design. Kris Martinson 1 Quote
wombatie Posted April 27 Posted April 27 That is a beautiful piece. Well done Kris. Marg Kris Martinson 1 Quote
Denny Knappen Posted April 27 Posted April 27 Well Done on a beautiful pattern. Kris Martinson 1 Quote
Old Joe Posted April 29 Posted April 29 On 4/26/2026 at 4:52 PM, Kris Martinson said: I just finished cutting this. Lots of hours at the scroll saw. Pattern by me. I haven’t been on here much for a while, but your patterns keep getting better and better, Kris. Nicely cut, too. Kris Martinson 1 Quote
rjweb Posted April 29 Posted April 29 Kris, I believe you said you use 1/8 inch BB. If you use tape on wood and then glue Pattern on tape do you have trouble removing tape when done because it looks very fragile, RJ Kris Martinson 1 Quote
preprius Posted May 1 Posted May 1 I like it. The girl is native American Indian which make the scene so much better. Me. Mark Eason Kris Martinson 1 Quote
Kris Martinson Posted May 13 Author Posted May 13 On 4/29/2026 at 11:16 AM, rjweb said: Kris, I believe you said you use 1/8 inch BB. If you use tape on wood and then glue Pattern on tape do you have trouble removing tape when done because it looks very fragile, RJ I do not use tape. I glue the pattern directly onto the wood with 3M 77 Spray Adhesive. I remove it when finished with denatured alcohol. Easy-peasy. Scrappile 1 Quote
Kris Martinson Posted May 20 Author Posted May 20 On 4/29/2026 at 11:16 AM, rjweb said: Kris, I believe you said you use 1/8 inch BB. If you use tape on wood and then glue Pattern on tape do you have trouble removing tape when done because it looks very fragile, RJ Sorry for the late reply. I do not use tape. I just apply patterns with 3M Super 77 spray adhesive. To remove the patterns I coat them with alcohol, and they peel right off easily. Quote
